360 into an A-body #498790
10/16/09 05:03 PM
10/16/09 05:03 PM
Winterville, Ga USA
rogue_leader007 Offline OP
Winterville, Ga USA
I'm swapping a 360 into my 70 dart, which is a former slant 6 car. I'm going to use the schumacher mount kit and was wondering if I'm going to have to get a drop center link. Or is that just for the early a-bodies?
Thanks for any info.
Re: 360 into an A-body [Re: rogue_leader007] #498791
10/16/09 06:13 PM
10/16/09 06:13 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
You should be fine on the 70 model.
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: 360 into an A-body [Re: rogue_leader007] #498792
10/16/09 06:27 PM
10/16/09 06:27 PM
should already have the dropped center link. prepare to do ALOT of shimming on the
mounts to get the alignment right.
Re: 360 into an A-body #498793
10/16/09 06:32 PM
10/16/09 06:32 PM
Clarksville, Tennessee
monoptn Offline
mopar addict
monoptn  Offline
mopar addict
I dropped a 360 in a demon using those mounts and didn't have to shim at all. It dropped right in perfectly. The power steering line coming out of the back of the Saginaw pump hit the K frame, and I had to trim the point off the frame with a grinder.
Re: 360 into an A-body [Re: monoptn] #498794
10/16/09 06:41 PM
10/16/09 06:41 PM
Ridley Park, Pa.
69MOPE Offline
super gas
69MOPE  Offline
super gas
Ridley Park, Pa.
If the 360 came out of a truck, the pan won't work.
Re: 360 into an A-body [Re: monoptn] #498795
10/16/09 07:12 PM
10/16/09 07:12 PM
haha your right... i was thinkin' of that 440 install. my appologies.
Re: 360 into an A-body [Re: 69MOPE] #498796
10/17/09 11:32 AM
10/17/09 11:32 AM
Winterville, Ga USA
Winterville, Ga USA
I already have a pan to replace the truck style one that's on my 360. It came from a early 70s C-body according to the number on it.
Thanks for the info. Mopar parts are hard to come by in my neck of the woods here in NE Georgia. And the guys who have mopar stuff around here tend to hoard it and ask for a king's ransom for anything. They are never willing to part out stuff either.
*still want that 69 Charger that's in the junkyard in Lavonia*
Thanks again for the info.
