Bootless plugs for header clearance #498707
10/16/09 04:39 PM
10/16/09 04:39 PM
ILL
mark7171 Offline OP
mark7171  Offline OP
ILL
I took the boots off the 90 deg spark plug wires so they would fit the headers. the metal fitting is tight and no contact is made, but can it arc out to the header at high RPM's ? Seems to work so.
What epic fails await...?
360, sml bk summit headers, B body
Re: Bootless plugs for header clearance [Re: mark7171] #498708
10/16/09 04:53 PM
10/16/09 04:53 PM
SW Fla.
CYACOP Offline
CYACOP  Offline
SW Fla.
"What epic fails await...?"
You will not fail to scream @#%$#@!$%%# when you forget there is no boot installed.
Re: Bootless plugs for header clearance [Re: mark7171] #498709
10/16/09 05:16 PM
10/16/09 05:16 PM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
Use Rajah terminals to solve your problem.
Re: Bootless plugs for header clearance [Re: CYACOP] #498710
10/16/09 09:59 PM
10/16/09 09:59 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I hear it'll arc to the header tube at higher rpms. I would just the header until there's enough clearance. I had to do this in-car on mine, it was no fun, but I came up with a redneck way of doing it that worked for me.
Re: Bootless plugs for header clearance [Re: DaytonaTurbo] #498711
10/16/09 10:15 PM
10/16/09 10:15 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Accel makes shorty spark plugs for headers.
Re: Bootless plugs for header clearance [Re: Commando1] #498712
10/16/09 11:18 PM
10/16/09 11:18 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I've had no luck getting a return call from the only guy I found on the internet selling them..
Re: Bootless plugs for header clearance [Re: 1_WILD_RT] #498713
10/17/09 08:50 AM
10/17/09 08:50 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Ran those headers on my Ram and the kids 318 Charger.Had no problems with Taylor wires.Mine were on for 4 years and never any problems.The Charger had them on for 2 years.Rocky
Chrysler Firepower
Re: Bootless plugs for header clearance [Re: 1_WILD_RT] #498714
10/17/09 09:37 AM
10/17/09 09:37 AM
Commando1 Offline
Commando1  Offline
http://www.thehotrodcompany.com/shopnow/show_search.asp
