5 sd auto slap stick #498270
10/15/09 10:08 PM
10/15/09 10:08 PM
minot north dakota
ledft79 Offline OP
ledft79  Offline OP
minot north dakota
with out going to a ratchet shifter, how could I get my 3 speed slap stick to work on a 5 speed auto. Does anyone know of a company that makes a 5 speed slap stick to fit an E body. I realy hate ratchet shifters, and I do like slap sticks
DRIVE EM, DONT HIDE EM.
Re: 5 sd auto slap stick [Re: ledft79] #498271
10/16/09 06:52 AM
10/16/09 06:52 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
5 speed? what tranny are you using?
2017 Grand Cherokee Overland
Re: 5 sd auto slap stick [Re: patrick] #498272
10/16/09 10:22 AM
10/16/09 10:22 AM
minot north dakota
ledft79 Offline OP
ledft79  Offline OP
minot north dakota
the trany is a 5 speed auto, out of a 2004 dodge pickup with a 5.7 hemi, that I am going to put into a 71 dodge challenger.
Re: 5 sd auto slap stick [Re: ledft79] #498273
10/16/09 10:28 AM
10/16/09 10:28 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
545RFE then....just wondering, as there is also the A580 in the LX's...
Re: 5 sd auto slap stick [Re: ledft79] #498274
10/16/09 10:46 AM
10/16/09 10:46 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Are you good at building circuit boards? Those are electronic transmissions. The shifter in the console is a computer with a lever sticking out of it.
- Stu Harmon
Re: 5 sd auto slap stick [Re: feets] #498275
10/16/09 12:40 PM
10/16/09 12:40 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
A580, definitely (I used to work for the company that makes all the shifters for the A580). the cable essentially is only used to get the tranny out of park.
545RFE I don't know, that one the shifter might actually control gear postion....
Re: 5 sd auto slap stick [Re: patrick] #498276
10/16/09 06:48 PM
10/16/09 06:48 PM
minot north dakota
ledft79 Offline OP
ledft79  Offline OP
minot north dakota
I do not know which one it is for sure, I didn't know that they were electronic shift. That kind of puts a twist on things. So what would be a good choice for a shifter set up, preferably one that would fit my E body councel.
Re: 5 sd auto slap stick [Re: ledft79] #498277
10/16/09 10:45 PM
10/16/09 10:45 PM
Mission BC
10sec440 Offline
10sec440  Offline
Mission BC
545RFE:
OPERATION
MANUAL LOW (1) range provides first gear only. Overrun braking is also provided in this range. MANUAL SECOND (2) range provides first and second gear only.
DRIVE range provides FIRST, SECOND, THIRD, OVERDRIVE FOURTH, and OVERDRIVE FIFTH (if applicable) gear ranges. The shift into OVERDRIVE FOURTH and FIFTH (if applicable) gear ranges occurs only after the transmission has completed the shift into D THIRD gear range. No further movement of the shift mechanism is required to complete the 3-4 or 4-5 (if applicable) shifts.
The FOURTH and FIFTH (if applicable) gear upshifts occur automatically when the overdrive selector switch is in the ON position. No upshift to FOURTH or FIFTH (if applicable) gears will occur if any of the following are true:
The transmission fluid temperature is below 10° C (50° F) or above 121° C (250° F).
The shift to THIRD is not yet complete.
Vehicle speed is too low for the 3-4 or 4-5 (if applicable) shifts to occur.
Upshifts into FOURTH or FIFTH (if applicable) will be delayed when the transmission fluid temperature is below 4.5° C (40° F) or above 115.5° C (240° F).
Re: 5 sd auto slap stick [Re: ledft79] #498278
10/17/09 07:25 AM
10/17/09 07:25 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
rams never came with the A580, so it is a 545RFE.
