Need a good, inexpensive fuel pressure regulator #495203
10/12/09 11:25 AM
10/12/09 11:25 AM
MA
Mass_Mopar Offline OP
MA
Any recommendations? For the New Yorker. 440, 4bbl carter, 3/8" line, carter elec fuel pump rated at 6psi.
The carb really wants ~4psi, so an adjustable pressure regulator in the 3-6psi region will work.
Tried all the local stores. AutoZone had one for $25 bucks made by Spectre that was junk, worked great for 1 fire up, then shut off/stuck closed and we couldn't get it to work again and returned it.
Re: Need a good, inexpensive fuel pressure regulator [Re: Mass_Mopar] #495204
10/12/09 11:29 AM
10/12/09 11:29 AM
Wisconsin USA
Bill MeLater Offline
Wisconsin USA
The cheap Holley's seem to be reliable...
Re: Need a good, inexpensive fuel pressure regulator [Re: Mass_Mopar] #495205
10/12/09 12:24 PM
10/12/09 12:24 PM
hooziewhatsit Offline
Sounds just like the one I got.. a year ago, so it's too late to return
I'm also looking for a good one...
Re: Need a good, inexpensive fuel pressure regulator [Re: Bill MeLater] #495206
10/12/09 12:27 PM
10/12/09 12:27 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Those are what are on both our cars.
Re: Need a good, inexpensive fuel pressure regulator [Re: WILD BILL] #495207
10/12/09 01:37 PM
10/12/09 01:37 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I used one of the cheapie holley's before with good results as well.
Re: Need a good, inexpensive fuel pressure regulator [Re: DaytonaTurbo] #495208
10/12/09 02:17 PM
10/12/09 02:17 PM
Ma, USA North of Boston
74SatSundance Offline
Holley 12-803BP 4.5-9 psi
Here is the site with other holley regulator options available.
Holley regulators
You should be able to get these thru your local parts store that can get hipo stuff.
I believe the first one has: one input and 2 outputs.
I put an elbow on one of the outlets and screwed in a small pressure gauge.
It works great, had it on there for a few years now.
Re: Need a good, inexpensive fuel pressure regulator [Re: 74SatSundance] #495209
10/12/09 02:51 PM
10/12/09 02:51 PM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
The cheapie Summit regulator says Holley right on it.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: Need a good, inexpensive fuel pressure regulator [Re: CJK440] #495210
10/12/09 02:59 PM
10/12/09 02:59 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
I have a unused Summit regulator laying around here some where. Uses regular pipe barbed fittings.
Re: Need a good, inexpensive fuel pressure regulator [Re: CJK440] #495211
10/12/09 03:03 PM
10/12/09 03:03 PM
USA
JoesMopar Offline
JoesMopar  Offline
USA
I'm using a Summit regulator on my '69 Charger, works great.
Re: Need a good, inexpensive fuel pressure regulator [Re: 74SatSundance] #495212
10/12/09 03:07 PM
10/12/09 03:07 PM
Holley regulators
Interesting, apparently the 12-803BP is not to be used with mechanical fuel pumps.
http://www.holley.com/data/Products/Technical/199R7914-3.pdf
The 12-803 is $27 at Summit, and the Summit brand is $25. I guess they're fine to use with mechanical pumps.
Re: Need a good, inexpensive fuel pressure regulator [Re: hooziewhatsit] #495213
10/12/09 03:17 PM
10/12/09 03:17 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
Don't use the Mr Gasket either, same junk as the Specter...
