Where would you start-elec problem
#494647
10/11/09 11:51 PM
10/11/09 11:51 PM
Posts: 3,712 Sacramento, Ca
Darius
Sacramento, Ca
I replaced my battery because I kenew the old one to be wearing out. It was completely dead one day so I bought a new one. I went on one cruise the day after installing the new one, appx 3 weeks ago, and today the new battery is completely dead. What is a logical trouble shoot on this type issue? No switches were left on, that was the first thing I checked. Car is a 69 Dart GTS 340 not any elec mods other than ignition and an electric choke.
Driving modern convenience in classic beauty
Re: Where would you start-elec problem
[Re: Darius]
#494648
10/12/09 12:18 AM
10/12/09 12:18 AM
Posts: 4,861 Riverside, Ca
R70RUNNER
Riverside, Ca
either not charging correctly or a short? did you have the alt checked? (take it to Autozone for a free check) if you suspect you have a short? remove neg cable, hook a volt meter between the cable end a the batt terminal. MAKE SURE key off doors closed all lights off...car should be just about elect dead
If you show volt draw, start pulling fuses one by one
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
[Re: R70RUNNER]
#494649
10/12/09 12:48 AM
10/12/09 12:48 AM
RapidRobert
With your VOM on "volts" check the charging voltage at a fast idle at the battery and at the alt & as R70runner said take off either batt cable & set your VOM on "amps" & hook it inline between the cable end and the batt post. With everything off should be no draw, then switch to milli amps & should be no draw. Start on the amps scale then move to milliamps if the amps scale shows zero.
[Re: RapidRobert]
#494650
10/12/09 08:23 AM
10/12/09 08:23 AM
Darius
Sacramento, Ca
Thanks guys, I will try as suggested and see what I come up with.
[Re: Darius]
#494653
10/12/09 10:25 AM
10/12/09 10:25 AM
Posts: 1,822 Colorado
denfireguy
Colorado
Does your car have a clock? The old mechanical wind clocks drew enough to kill a battery after a three weeks of inactivity. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: RodStRace]
#494655
10/12/09 07:59 PM
10/12/09 07:59 PM
Darius
Sacramento, Ca
I am thinking there is a draw somewhere. It was a brand new battery and I started the car maybe 4 times with it in two days, then it sat in the garage for about 3 weeks before I went to start it again.There are NO aftermarket electrical items installed on this car other than electronic ignition and an electric choke on the carb. I'm thinking it may be a switch sticking somewhere like a brake light or interior trunk light maybe since I didn't notice the brake lights on and I walk around the back of the car to lock the garage. I will try the meter/check fuse method first and see what happens.......once I take the battery and get it fully charged again.
