Installing an adjustable proportioner valve #494038
10/11/09 01:49 PM
10/11/09 01:49 PM
moparmedic Offline OP
I'm doing another disc brake conversion and this time I want to use an adjustable valve for metering the pressure on the rear brakes. Where is the appropriate place to install it? Between the master cylinder and the block on the frame rail or behind the block on the frame rail? or does it even matter as long as it goes on the rear brake line?
Pictures would help, thanks.
1968 Coronet
1968 Charger
1966 A100 Pickup
1967 Barracuda
1970 Challenger
1972 Challenger
1973 Barracuda
2021 Ram 2500
Re: Installing an adjustable proportioner valve [Re: moparmedic] #494039
10/11/09 02:36 PM
10/11/09 02:36 PM
Raleigh, NC
Y
Youngblood Offline
Youngblood  Offline
Y
Raleigh, NC
anywhere in rear line, next to master is easy to get to, but you won't be adjusting it often
Re: Installing an adjustable proportioner valve [Re: Youngblood] #494040
10/11/09 02:47 PM
10/11/09 02:47 PM
Can the block that is mounted on the frame rail stay or does it need to be removed. I think it is just the low brake pressure switch and distribution, correct?
It is all original equip and had front and rear drums.
1968 Coronet
1968 Charger
1966 A100 Pickup
1967 Barracuda
1970 Challenger
1972 Challenger
1973 Barracuda
2021 Ram 2500
Re: Installing an adjustable proportioner valve [Re: moparmedic] #494041
10/11/09 10:03 PM
10/11/09 10:03 PM
Here
DirectSubjection Offline
Tacohead. The First and Only
Here
Sounds like a distribution block in which case it can stay. I put mine up by the master cylinder.
Ride eternal, shiny and chrome
Re: Installing an adjustable proportioner valve [Re: DirectSubjection] #494042
10/12/09 12:01 AM
10/12/09 12:01 AM
Thanks a lot..............
1968 Coronet
1968 Charger
1966 A100 Pickup
1967 Barracuda
1970 Challenger
1972 Challenger
1973 Barracuda
2021 Ram 2500
Re: Installing an adjustable proportioner valve [Re: moparmedic] #494043
10/12/09 06:35 PM
10/12/09 06:35 PM
Hunt Valley, Maryland
1fastrunner Offline
1fastrunner  Offline
Mine is right up by the master, we just got a small brake line and bent it to work. that way we didn't have to mess with any fittings.
