HOW TO INSTALL SPIROLOX? #492429
10/09/09 01:30 PM
10/09/09 01:30 PM
elmira ny
hp340nos Offline OP
hp340nos  Offline OP
elmira ny
which way do i rotate the spirolox into the piston clockwise or counter clockwise,ive never used these before?thanks mike
Re: HOW TO INSTALL SPIROLOX? [Re: hp340nos] #492430
10/09/09 01:38 PM
10/09/09 01:38 PM
SW Ohio
cgall Offline
cgall  Offline
SW Ohio
Think of it as a spring, you pull it apart about 1/8", then work the first end into the groove, then rotate around to thread the other coils in.
The fun part is taking them out after realizing that you put 5 of your 8 pistons on backwards.
Re: HOW TO INSTALL SPIROLOX? [Re: cgall] #492431
10/09/09 01:44 PM
10/09/09 01:44 PM
elmira ny
hp340nos Offline OP
hp340nos  Offline OP
elmira ny
i will try that,yes i marked the pistons and rods so i put them on right the 1st time.thanks mike
Re: HOW TO INSTALL SPIROLOX? [Re: hp340nos] #492432
10/09/09 01:54 PM
10/09/09 01:54 PM
ky
68roadrunner Offline
ky
don't think it matters, have never read anything about direction. i personally stagger the ends of the two.
Re: HOW TO INSTALL SPIROLOX? [Re: 68roadrunner] #492433
10/09/09 02:10 PM
10/09/09 02:10 PM
Longview, Texas
marvo451 Offline
marvo451  Offline
Longview, Texas
And when you get through, 2 types of alcohol are almost a necessity. Isopropyl for your cuts and gouges and Ethyl for your nerves and to help you relax.......
Re: HOW TO INSTALL SPIROLOX? [Re: marvo451] #492434
10/09/09 02:15 PM
10/09/09 02:15 PM
IL
knyech1 Offline
knyech1  Offline
IL
That's what I should have done!!!!
knyech1- '71 Sassy Grass Demon 340/904. Pump gas, 1.61 60ft, 7.439 1/8 @ 95mph, 11.824 1/4 @ 111mph "Not too bad for a pump gas 340, full of used parts and hillbilly ported stock heads." - V.B. '03 2500 5.9L HO 6-spd on 35's. 395hp/755ft-lb at tires.
Re: HOW TO INSTALL SPIROLOX? [Re: knyech1] #492435
10/09/09 02:17 PM
10/09/09 02:17 PM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
Is there a sharp edge and a rounded edge or is that just C-clips??
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: HOW TO INSTALL SPIROLOX? [Re: CJK440] #492436
10/09/09 02:49 PM
10/09/09 02:49 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
No,they can go in either direction and side.
Re: HOW TO INSTALL SPIROLOX? [Re: B G Racing] #492437
10/09/09 03:13 PM
10/09/09 03:13 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
i stretch mine out so they are about a 1/4" sprung (heightwise). makes them easier to get in the groove
Re: HOW TO INSTALL SPIROLOX? [Re: aarcuda] #492438
10/09/09 03:19 PM
10/09/09 03:19 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
That works and we take a hard plastic round stock and sharpen the end like a screwdiver(flat) and use it to work the spiral into the groove.You made have to dress up the end once in a while,but it saves finger nails and finger tips and it dosn't damage the lock or piston.
Re: HOW TO INSTALL SPIROLOX? [Re: B G Racing] #492439
10/09/09 06:55 PM
10/09/09 06:55 PM
elmira ny
hp340nos Offline OP
hp340nos  Offline OP
elmira ny
thanks for the help guys i got them all in and done,now for some seagrams 7 and 7/up,only 2 cuts and all fingers are in tack.thanks again mike
Re: HOW TO INSTALL SPIROLOX? [Re: hp340nos] #492440
10/09/09 10:42 PM
10/09/09 10:42 PM
Cab_Burge Online work
Cab_Burge  Online Work
I always install mine counter clockwise
Re: HOW TO INSTALL SPIROLOX? [Re: Cab_Burge] #492441
10/10/09 12:36 AM
10/10/09 12:36 AM
elmira ny
hp340nos Offline OP
hp340nos  Offline OP
elmira ny
thats how i installed them counter-clockwise,thanks mike
Re: HOW TO INSTALL SPIROLOX? [Re: Cab_Burge] #492442
10/10/09 12:42 AM
10/10/09 12:42 AM
Wheels up, MO
N
nhramark Offline
nhramark  Offline
N
Wheels up, MO
The only bad experience I had with assembling my motor was installing the spirolox. I think I would rather just buy new pistons and rods than try to remove them.
[image]http://s1126.photobucket.com/user/nhramark1/library/Racing[/image] 9.100 @ 150 mph 5.780 @ 120 mph
Re: HOW TO INSTALL SPIROLOX? [Re: nhramark] #492443
10/10/09 06:54 AM
10/10/09 06:54 AM
Clinton Township, Michigan
Dartin Offline
Dartin  Offline
After you bloody up your fingers and destroy the first one you get the hang of ir quick! I had nightmares for weeks after installing my first set.
Yeah, how do you get them out???
Re: HOW TO INSTALL SPIROLOX? [Re: Dartin] #492444
10/10/09 11:17 AM
10/10/09 11:17 AM
some pistons have a machined groove to help get a real thin pick under the tangs on the end of the spirolocs, some don't If yours don't you have to use the pick under the edge of the tang to lift them up high enough and try to get another pick or thin screwdriver blade unde it to help walk them out It takes practice, just like putting them in
Re: HOW TO INSTALL SPIROLOX? [Re: Cab_Burge] #492445
10/10/09 11:24 AM
10/10/09 11:24 AM
SW Ohio
cgall Offline
cgall  Offline
SW Ohio
Just as Cab said, the outside edges have an undercut radius that allows you to get a pick in there, lift it just enough to get a small screwdriver under it, start working it out with another screwdriver. I think Powerhouse has a tool for install/removal. It also helps to have three hands.
Re: HOW TO INSTALL SPIROLOX? [Re: aarcuda] #492446
10/10/09 11:43 AM
10/10/09 11:43 AM
Sherwood park, Alberta.
go green Offline
go green  Offline
I stretch them so they are at least a 1" long .
They push right in , they don't lose any diameter once they are in the groove .
Never had any cuts or problems.
6.50 @ 226 MPH 4.25 @ 186 MPH
https://www.youtube.com/watch?v=YX86DHGKBo0
