Hi-Low Mopar Horn Fix? #491566
10/08/09 12:06 PM
10/08/09 12:06 PM
Utah
W
WAJ Offline OP
WAJ  Offline OP
W
Utah
I've read about squirting WD-40 down inside the Mopar horns to revive them. What's the best process to get all the rust and etc. out of these horns please?
Thanks a lot!
Re: Hi-Low Mopar Horn Fix? [Re: WAJ] #491567
10/08/09 12:45 PM
10/08/09 12:45 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
For what it is worth WD40 is not a good penitrating oil. It is more of water displacer. That is what it was meant to be.
Us some PB Blaster or some Knockerloose.
Do they just make small noise or what. Have your tried to adjust it out of them buy turning on the tuner knob. It is the star shaped knob on them.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: Hi-Low Mopar Horn Fix? [Re: MoparforLife] #491568
10/08/09 12:47 PM
10/08/09 12:47 PM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
Knockerloose?? Sounds like a wardrobe malfunction.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: Hi-Low Mopar Horn Fix? [Re: CJK440] #491569
10/08/09 12:49 PM
10/08/09 12:49 PM
State of Corruption
camdog440 Offline
camdog440  Offline
State of Corruption
Re: Hi-Low Mopar Horn Fix? [Re: camdog440] #491570
10/08/09 12:57 PM
10/08/09 12:57 PM
Upper Midwest
Upper Midwest
I knew that would come up but it is good stuff:
Re: Hi-Low Mopar Horn Fix? [Re: MoparforLife] #491571
10/08/09 02:45 PM
10/08/09 02:45 PM
Fortworth TX
mod5v Offline
mod5v  Offline
Fortworth TX
? are you trying to spray into the trumpet opening? The only thing that would do is possibly help dislodge dirt-etc.. The ""workings"" of the horn are sealed up inside the motor housing. There is a coil in there and a set of braker points. When the coil is enerjized the magnetic field draws a plunger (mobil nukleus) and that plunger opens the points and that drops out the "magnetic" field and repets.... as long as you hold the power to the horn. The "star wheel screw" adjusts the distance the points are from the "mobil nukleus". You should have continuity thru the horn. The "housing" is ground on most single terminal horns. ohms should be about 2to5 omhs.
Re: Hi-Low Mopar Horn Fix? [Re: mod5v] #491572
10/08/09 03:02 PM
10/08/09 03:02 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
screw in and out couple of times the tune screw to help to loose it and then tune up again.
In fact you can remove the screw, spray in through the hole some cleaner, shake it, drip the cleaner through the hole, fit the screw back and tune up.
Re: Hi-Low Mopar Horn Fix? [Re: MoparforLife] #491573
10/08/09 04:35 PM
10/08/09 04:35 PM
Utah
W
WAJ Offline OP
WAJ  Offline OP
W
Utah
Thanks!
