Re: 700 HP small block
[Re: emarine01]
#491473
10/08/09 12:33 PM
10/08/09 12:33 PM
Posts: 5,484 SoCal
Brian Hafliger
SoCal
Any 59* 700 hp combos around, whats it take to do? Is there a point of no return on the 59* block?
Both W2Stroker and DiegoTed have near 700HP engines we built a couple of years ago. Ted's made 678 and Martin's made 685. 4" cranks, 59° R blocks, 13:1, roller cams, one had Indy cnc -2 heads the other my ported Batten W2 heads, Indy intakes and 1050 dominators. No special ring stack, no vacume pumps or other trick parts. Both used an 1 7/8 header. The cams were NOS cams, so there was a little HP left on the table but probably only 20Hp maybe?
Both engines were built with RELIABILITY in mind and not pushed hard to make HP.
Brian Hafliger
[Re: emarine01]
#491474
10/08/09 12:36 PM
10/08/09 12:36 PM
Posts: 13,354 Marion, South Carolina [><]
an8sec70cuda
I'm not 100% sure, but I think Johnny Pennington's small block fits what you described. He's from Lexington, SC. Blue with purple stripes Dodge Dart running 9.60s. CHIP
[Re: emarine01]
#491476
10/08/09 01:25 PM
10/08/09 01:25 PM
ggddemon
I have a 2880lb./ 59*/ r-3 /w-9 glide setup this year, worked o.k...did a best of 6.04@113 in the 660'and 1 run in the 1320 was 9.64@138- old setup was a eddy top end that did 6.26@109 in the 660' Dave
[Re: ggddemon]
#491478
10/08/09 01:47 PM
10/08/09 01:47 PM
Posts: 11,706 Portage,michigan
B3422W5
Portage,michigan
Personally, i dont see a 59 degree head(except the latest and best indy head)making an honest 700 ponies, based on the old "riders dyno" benchmark.
I know w5's wont do it, w2 wont, the b1ba and eddies wont, so that leaves some sort of 245 indy head as the only way of getting there
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: B3422W5]
#491480
10/08/09 02:42 PM
10/08/09 02:42 PM
Posts: 5,484 SoCal
Brian Hafliger
SoCal
I believe our dyno to be "accurate". My engine made 560HP and runs 10.50's in 2500d.a. air in my 3320lb. duster with me in it. MPH is usually 125-126. To me, that's pretty accurate "comparing" other engines I dyno vs. customers cars. Most combo's that don't "perform" as they dyno suggests are most likely lacking in the chassis and 60ft. over the dyno.
My car has gone 1.37-1.3960ft. Usual is 1.41. I'm sure that when our dyno reads close to 700HP, it's accurate. I can't speak for anyone else's dyno but knowing what your dyno #'s read vs. in car performance vs. the chassis combo is KEY to getting the car to do whatever the customer wants it to do. Indy heads flow well, and I find it hard to believe that you think 700HP is unattainable by them in all but the biggest port they offer! But your allowed to "think" whatever you want...
Brian Hafliger
[Re: Brian Hafliger]
#491481
10/08/09 03:07 PM
10/08/09 03:07 PM
Posts: 1,418 Mcallen, TX
SB449VALIANT
Mcallen, TX
don,t really like indy stuff, but the heads are ready avalible,not really sure about the INDY RP. you will have to talk to ryan, the 449 ryan built me was well over the 700hp.just make sure you don't deal direct with them,service is not a favor, they just think that way, IMHO. If my memory serves correctly ,my engine was suppose to be built at the beginning with a set of w9 ab's, with lots of CSA, and we were going to be using a tall deck 48* r3 with a max bore,but heyy!!! those blocks are pigs... that stoped me from going that route, then i scored a nice brand new in the box x block,and we went from there, Ryan built me this complete top set up from ICH....not bad for a true 59* block at 770hp and 615 torque. gilberto
[Re: Leigh]
#491483
10/08/09 03:36 PM
10/08/09 03:36 PM
SB449VALIANT
Mcallen, TX
speculate this... Will be 449 cubic inches, Should make around 730-740 HP @ 7200 RPM, 610-620 TQ @ 5100 RPM @ 2700 lbs 8.90 @ 152 @ 2600 lbs 8.80 @ 154 @ 2500 lbs 8.70 @ 156
[Re: SB449VALIANT]
#491486
10/08/09 03:58 PM
10/08/09 03:58 PM
Posts: 6,314 The Swamp
MegaDart
The Swamp
A friend went 9.0's at 2450 in a 70 cuda just on gas with little b1ba heads. We figured at that weight he was about 620 real horsepower. So you were about 150 pounds heavier than he was.
Please, let's only talk about first hand experience here, not a friend of a friend blah, blah, blah. You know all racers are liars he probaby weighs 2200lb!!lol And we are supposed to believe someone who list there car as having "bicycle tires" does that is some weird way make you feel good??
fyi, my car actually weighed 2650+ lbs, had a huge frontal area and burned up high gear clutches when it ran those #'s. Ask Laverne, he saw the trans first hand. things the Moroso calculator can not figure in...
Amen to that! I think ou812 has a clue
[Re: MegaDart]
#491488
10/08/09 04:59 PM
10/08/09 04:59 PM
Posts: 1,019 Finland
mafo
Finland
My old motor had really radical batten w2`s(340cfm)on a x-block 4,10x3,42,dual dominators and dry sump(no vacum pump) Best et was 9,39@143 in a 2900 pound Valiant on dot tires
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
[Re: instigator]
#491491
10/08/09 05:56 PM
10/08/09 05:56 PM
MegaDart
The Swamp
Wallaces calculator says I make 1108 flywheel hp to run 128mph in the 1/8th at 3400lbs!
59deg 408ci edelbrock heads.
which calculator and what was the ET??
[Re: MegaDart]
#491492
10/08/09 06:07 PM
10/08/09 06:07 PM
B3422W5
Portage,michigan
No, its not idle talk, and many members on here are intimately familiar with the car, its weight, and its combo.He racedit at many Classi events in super pro, and at 131 forever.
It is soon to come back out with a w9 motor Best machine built and Dyno'ed that makes the kinda power your "w5 motor" made..We will see how far in the 8's it runs on gas.
So if your car at 150 pounda heavier ran the same numberS on injected alky as his diD, you are way off at 741 ponies.
This very subject was beat to death on one of Ryans thread several years ago, .
Your car ran good, but 741 horse is a dream you need to let go of one of these years, Wayne.
[Re: instigator]
#491494
10/08/09 06:27 PM
10/08/09 06:27 PM
MegaDart
The Swamp
Your HP computed from your vehicle ET is 954.08 flywheel HP and 858.672 rear wheel HP. Your HP computed from your vehicle MPH is 1,108.08 flywheel HP and 0.9 rear wheel HP
your car is awesome instigator but I am not sure why the 0.9 rear wheel HP on the calculator??
whatever Don. I certainly don't want to relive that pissin' match anytime soon.
emarine, it is absolutely possible. Call Bill Richardson at RAM racing if you need some ideas. He had forgotton more about sbm's then most here ever knew...
[Re: an8sec70cuda]
#491495
10/08/09 09:28 PM
10/08/09 09:28 PM
Posts: 125 Lexington South Carolina
johnnyp
Thanks for thowing mine in to the mix, Chip But I have nothing for any of these cars in this post my car weighs to much for them.
[Re: B3422W5]
#491496
10/08/09 09:36 PM
10/08/09 09:36 PM
Posts: 1,596 BX, CT, FL.
B1KILLER
BX, CT, FL.
The only way to go
[Re: emarine01]
#491497
10/08/09 10:42 PM
10/08/09 10:42 PM
Posts: 293 Michigan
ccarson
420 CU IN, W9, 13:1 Comp, .728 lift Roller, 280 Dur.@50 yes it can be done but I wish we would have went with a 48 Deg Block.
[Re: ccarson]
#491498
10/08/09 11:33 PM
10/08/09 11:33 PM
Posts: 1,745 Maryland
340_Dart
Maryland
420 CU IN, W9, 13:1 Comp, .728 lift Roller, 280 [Email]Dur.@50[/Email]
I know this will probably be a stupid question, but what would the advantage have been if you used a 48* block? The only difference is the valvetrain is more stable at high rpm, correct?
[Re: emarine01]
#491499
10/08/09 11:52 PM
10/08/09 11:52 PM
Posts: 243 NJ
arc
NJ
[Re: B3422W5]
#491500
10/09/09 12:02 AM
10/09/09 12:02 AM
Posts: 374 kalamazoo, MI.
VIPERDUST
kalamazoo, MI.
Yes the car went 9.03@146, and weighs 2450, all with 400 cubes and b1 heads. So B3 was right.
[Re: ccarson]
#491502
10/09/09 01:07 AM
10/09/09 01:07 AM
Posts: 2,864 IN
Irun5snd8th
IN
According to the calculators my car has to be making near 620 HP to push 3000 lbs to 9.80's at 133. I have eddies on mine so I seriously cannot believe that it would be that difficult to get 700 out of a good set of heads.
AFCO, Rons Fuel Injection sponsored Dodge Challenger
Mention Street Lethal Motorsports
[Re: emarine01]
#491505
10/09/09 08:17 AM
10/09/09 08:17 AM
Posts: 506 Texas Afghanistan Iraq etc.
DakFink
There are a few around. I don't know any personally but run across them occasionally.
What it takes??
Well that all depends on what your after and how much $$$$ you want to spend.
You want N/A, Nitrous or Boost????
Why are you sticking with a 59* block? If you already have a Block understandable. If your starting from scratch might as well get a 48* if you can. Easier head options available to work with.
Point of No Return. I guess your really asking HP limit. Well that all depends? What block you use, how you make that power and what you use it for.
There are at least 3-4 Flavors of 59* block that I know of (maybe more) Factory LA, Magnum R-3, Resto-Blocks and the X-Block can all be had in 59* flavor as far as I know.
As far as the easiest way to get a 700+hp Mopar Small Block. As was stated!! R5-P7 Nascar Motor.
Not sure how much they are going for now, but they were about $6500 complete and running about 2 yrs ago. Granted that was NASCAR Running. Not something you would put straight into a driver.
If your looking to build? There are some top-notch builder on here.
If your just curious?! Might want to check out some other Mopar pages as well.
[Re: jim sciortino]
#491507
10/09/09 10:24 AM
10/09/09 10:24 AM
B3422W5
Portage,michigan
I find it hard to believe that a 400+ ci W-5 couldn't hit an honest 700.
Not meaning to brag, but i think my W5 motor runs as good as pretty much anybodies around.
I have pretty much stock suspension, cheap shocks, and have been almost 135 at 3350 pounds with a 727.
I MIGHT be at 640 honest horse. I think with a hair bigger cam and a better set of headers there might be another 20-30 horse there, but i dont see 60. I might be wrong.
throw alky at it, it might get closer, i am sure.
[Re: DakFink]
#491510
10/09/09 11:01 AM
10/09/09 11:01 AM
Posts: 3,695 nc
emarine01
nc
The reason for the post was, I ran into a chevy 434cid dyno sheet bragging contest @ a local builders shop the other day and got to see the dyno #s on alot of the trucks and rails we run with Every one was over 700 ponies from all different builders with a guy Scott Scharoff< I think that was the builders name not sure of the spelling but sounds like the russian vodka> having built several of the engines, all in the low 700hp range under 8K, It seems that if I step up a class my W5 rig wont be too competitive @ around 600hp, my engine has not been on a dyno so I don't know the real hp of my engine but I think 600 is close, some of the trucks I have already out run in the past but the rails and the light jeeps kick butt, So I have been kickin around what it will take to build a 700hp small bock mopar to compete, I have a good set of W5s that flow 325@ 600 and I dont remember the 700 flow #s but there was a small increase over 600, I don't trust my 40 year old factory block or the 6 other small blocks I have collected to run a bore over 4.06, I have a good 4"light crank and a set of BME 6.123 rods and several solid rollers I can reuse, just lacking a solid game plan, money is a bit tight this year so throwing 12k into a small block is not a smart option, this is a mud motor so the torque needs to be way up with the hp curve
[Re: B3422W5]
#491511
10/09/09 11:01 AM
10/09/09 11:01 AM
Posts: 8,547 State College, PA
RyanJ
moparts member
moparts member
State College, PA
Just depends on the dyno. 340Ricks old 416 W5 on pump gas made 676? on Kammer & Kammer's dyno. That was pretty basic mild combo. On that dyno, it would have been pretty easy to make couple changes to motor & hit 700+.
If combo's are not ran on same dyno, there is no sense in trying to compare #s.
I see over on Yellowbullet one of this years Engine Masters competitors talking about how for some reason this year the dynos @ the contest are reading way low for everybody, & I pretty much figured that out after day 1. There's a pair of dyno's that are reading different this year compared to last..... Maybe they are new DTS's but I doubt it, I assume they are the exact same ones as used for last couple years & for some reason they now read lower than in years past?
That's why I always ask potential customers 2 questions whenever they start spouting off about how much HP they "need" or "want".... I ask how much is car going to weigh, & how fast does it need to go? & I know based on experience what it will take to make it run the #. Sometimes what they want is unachievable... often times they are surprised when I tell them, Oh you don't need nearly as much power as you think to run those #'s. Everyone with a 3000-3100LB car thinks they need 700 HP to run a 9.90 or 10.0... & you don't.
Don your W5 motor put on Kammer&Kammer, or BES's Dyno would make at least 690's as it sits, throw a vacuum pump on or maybe convert intake to 4500 flange & it would be easy over 700 on those dynos. It's just a # & is'nt worth arguing about.
[Re: emarine01]
#491512
10/09/09 11:11 AM
10/09/09 11:11 AM
Posts: 5,484 SoCal
Brian Hafliger
SoCal
If you find a nice block, and use your parts you should be able to be competitive with your competition from what you've stated. The heads might need a little attention, and you may need a vacume pump/low drag ring pack and you might not. Can you strike a deal with these dyno guys to dyno the engine before and after? I do this alot, charge the customer alot less to do the engine before and after, on same dyno to see the gains and find out how much you had from the start. Just a thought....
Brian Hafliger
#491513
10/09/09 01:03 PM
10/09/09 01:03 PM
MegaDart
The Swamp
That is a great idea, something I've always wanted to do but have not. But, every race motor I have gets put on a dyno before going in my cars.
[Re: emarine01]
#491515
10/09/09 01:57 PM
10/09/09 01:57 PM
Posts: 5,484 SoCal
Brian Hafliger
SoCal
I would only use an R block, either R1 if you can find one, or R3. I think there is an R1 on here right now for sale in Tx maybe??
When I do a W5 head, I remove the original seats and replace them because they are prone to moving/falling out! But I think you have good enough parts (minus the cam maybe) to do what you want, with a little more work.
Brian Hafliger
#491516
10/09/09 02:05 PM
10/09/09 02:05 PM
B3422W5
Portage,michigan
R blocks are fine
That said, i like the X blocks, reason being they are stock up top and will accept anybodies roller lifters, which is a plus,(in the 59 degree and roller cam world) and accesories, etc, are plenty beefy to handle anything a 59 degree head can dish out, and are lighter than an R3
Like any block, they should be sonic checked, mine has plenty of meat for another overbore and its currently at 4.100. Like any Mopar blocks, the thickness varies, hence why they all should be checked.I know guys running them at 4.125 even, and making good power with safe bore thickness.
[Re: B3422W5]
#491517
10/09/09 02:14 PM
10/09/09 02:14 PM
SB449VALIANT
Mcallen, TX
R blocks are fine
Same thing here., my x block bore is 4.100 and it can take the 4.125 safetly....i guess..lol
#491518
10/09/09 02:16 PM
10/09/09 02:16 PM
Posts: 3,695 nc
emarine01
nc
I am not up to par on small block , blocks, is there a thread with a good description of the blocks , years or current availability and how much machine work ya gota do to make some power with one? We had to put a ton of time in money in the 360 block between line hone, steel caps,decking, bushed lifters, oiling mod, ect...
[Re: emarine01]
#491519
10/09/09 02:17 PM
10/09/09 02:17 PM
Posts: 4,084 Indiana
W5Duster436
Indiana
Ryan has an excellent FAQ about all this but currently his domain/website is unavailable.
'70 Duster - SDSS 436 W5 4spd (Gone) '71 Dodge D100 '70 Dodge W100
[Re: W5Duster436]
#491520
10/09/09 03:43 PM
10/09/09 03:43 PM
RyanJ
moparts member
moparts member
State College, PA
Yeah not sure why it's not back up yet... I'll get Dave on that on Monday. It usually does not take this long to come back up....
[Re: emarine01]
#491522
10/09/09 06:56 PM
10/09/09 06:56 PM
Posts: 5,484 SoCal
Brian Hafliger
SoCal
So far the older R1 blocks I've tested have been very good. Normally I see a min. of .210 on thrust and .280 non thrust at 4.060 bore.
R3's I've seen all over the place. Can't even remember that last time I saw an X block...I think maybe back in the 80's?? LOL!
Brian Hafliger
[Re: emarine01]
#491523
10/09/09 09:45 PM
10/09/09 09:45 PM
Posts: 182 usa
demon454
usa
I right now am building a R3 59' block to make 700 plus.It's a 454 stroker B1BA MC's flowing in the 360 range at 700 lift,W8 420 intake cut to fit 12.5 to 13.0 comp.1150 Dale Cubic carb,Haven't decided if i should dyno or not.
[Re: demon454]
#491524
10/09/09 10:06 PM
10/09/09 10:06 PM
Posts: 226 lino lakes,MN
onebaddakota
lino lakes,MN
I'm surprised no one has considered the new SB hemi. I know just from the head flow, the potential is there. They are now making kits up to 440 cubes for the 6.1L block. I believe Arrington even sells a pump gas, hyd roller crate motor that puts out 640HP
10.56 at 125.6, with a 1.43 60 ft.
E85, Hyd. Roller 410 magnum,full exhaust, 3500 race weight.
