'86 A833 OD vs. normal A833 bellhousing boltpatterns #491462
10/08/09 10:20 AM
10/08/09 10:20 AM
Virginia
HemiStan Offline OP
HemiStan  Offline OP
Virginia
Here's the situation:
I pulled an A833 OD unit from an '86(?) 318 2wd pickup this summer. I had the bearing retainer turned down a while ago. I have an old Lakewood bellhousing that I was going to bolt it up to this morning but the lower LH bolt hole seems to be in a location that is 5/16" higher than that of a regular A833. I've got a '68 23 spline with a bellhousing here that I compared it to. The Lakewood bolted up fine to the '68 tranny.
Has anyone run into this before? I had never heard of it.
I think I am going to cut off the threaded mounting tab on the inside of the Lakewood and weld it into a location that works with this OD unit.
Thanks.
Stan
Re: '86 A833 OD vs. normal A833 bellhousing boltpatterns [Re: HemiStan] #491463
10/08/09 10:40 AM
10/08/09 10:40 AM
lewiston, ID
cornucopia Offline
cornucopia  Offline
lewiston, ID
wow, never heard of that. wierd...
Re: '86 A833 OD vs. normal A833 bellhousing boltpatterns [Re: cornucopia] #491464
10/08/09 10:47 AM
10/08/09 10:47 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
I second that.
Re: '86 A833 OD vs. normal A833 bellhousing boltpatterns [Re: Commando1] #491465
10/08/09 11:01 AM
10/08/09 11:01 AM
Virginia
HemiStan Offline OP
HemiStan  Offline OP
Virginia
Here's a picture I just took. I tried to line the transmissions up so you could see the difference in the bolt holes.
Stan
Re: '86 A833 OD vs. normal A833 bellhousing boltpatterns [Re: HemiStan] #491466
10/08/09 11:11 AM
10/08/09 11:11 AM
Commando1 Offline
Commando1  Offline
Re: '86 A833 OD vs. normal A833 bellhousing boltpatterns [Re: HemiStan] #491467
10/08/09 11:37 AM
10/08/09 11:37 AM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
I have this '80 overdrive case with the hole in the correct location. PM me, I'll give you a good deal on it if you want it.
Re: '86 A833 OD vs. normal A833 bellhousing boltpatterns [Re: 446acuda] #491468
10/08/09 11:40 AM
10/08/09 11:40 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Why don't you just slot the hole in the trans to line up with the one in the bell housing?
Re: '86 A833 OD vs. normal A833 bellhousing boltpatterns [Re: stumpy] #491469
10/08/09 03:01 PM
10/08/09 03:01 PM
Virginia
HemiStan Offline OP
HemiStan  Offline OP
Virginia
Everyone, thanks for the replies!
Stumpy, I ended up slotting the hole in the transmission to line up. I didn't know if I would have enough metal there to do it but it seemed to work out OK. It just seemed more logical to alter this oddball transmission than alter a perfectly good Lakewood.
446acuda, I may take you up on that offer if this doesn't work out. Thanks.
Well, one step closer to completion.
Stan
