Re: Carb selection - upgrade stock 318 to 4 barrel-Options? [Re: gch] #490953
10/15/09 02:16 PM
10/15/09 02:16 PM
scratchnfotraction Offline
5/16 line is all you need for the swap at this level of performance
you would be surprized just how much it will support before needing to go to 3/8 line,IMHO
Re: Carb selection - upgrade stock 318 to 4 barrel-Options? [Re: scratchnfotraction] #490954
10/15/09 02:18 PM
10/15/09 02:18 PM
bout 300hp. after that, good luck.
Re: Carb selection - upgrade stock 318 to 4 barrel-Options? #490955
10/15/09 02:35 PM
10/15/09 02:35 PM
result do vary
and I was thinking about 350 hp myself
close enuff
and jumping from a stock 150 hp to 300hp is a big jump IMO,and the 5/16 line is doable
but a 4-v swap to a stock teen is not going to be that much HP to begain with..might bump it to 160 hp
headers have more of a boost than just swaping on a 4-v to a stock 318 in my book
Re: Carb selection - upgrade stock 318 to 4 barrel-Options? [Re: scratchnfotraction] #490956
10/15/09 02:43 PM
10/15/09 02:43 PM
5hp...w/ 4bbl carb/intake only...mabey... with a tail wind.
Re: Carb selection - upgrade stock 318 to 4 barrel-Options? #490957
10/15/09 03:12 PM
10/15/09 03:12 PM
Central NC
gch Offline
gch  Offline
Central NC
Dual exhaust is a must.Headers a plus.
Re: Carb selection - upgrade stock 318 to 4 barrel-Options? [Re: OLD318] #490958
11/15/09 09:42 PM
11/15/09 09:42 PM
i would use a edelbrock 600
Re: Carb selection - upgrade stock 318 to 4 barrel-Options? #490959
11/22/09 04:24 AM
11/22/09 04:24 AM
Portland Oregon
69Dartman Offline
69Dartman  Offline
Portland Oregon
I run a 9800 series Thermoquad on mine with the 340 exhaust all the way back and the early manifolds. works great with 95 or 92 jets and I think the 340 metering rods.
If you know how to work on one they are pretty much fully tweakable to run on just about anything. Mine pulls smooth, starts cold and runs great first try, and gets good MPG and power. Plus they sound awesome at WOT
Life's a little bit better when you hit a Camaro.
Re: Carb selection - upgrade stock 318 to 4 barrel-Options? [Re: 69Dartman] #490960
11/22/09 04:47 AM
11/22/09 04:47 AM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
My first car was a 318 Duster.I used a 600 Holley (old 6909) a Holley street dominator intake, stock 340 cam from the Chrysler dealer,and 1 5/8th's cheapo headers with Walker street Hemi mufflers spec'd for a Hemi Road Runner I got from NAPA.That combo worked great in that Duster and with a shift kit in the 904 and 2.76's out back,it got over 20 mpg easily.
Nautilus Racing-
Re: Carb selection - upgrade stock 318 to 4 barrel-Options? [Re: Chris2581] #490961
11/22/09 01:14 PM
11/22/09 01:14 PM
Va. Beach, Va
69superbee383 Offline
Va. Beach, Va
360 heads, thermoquad and a stock 68 MT 340 cam and some headers and duals. That ought to make a decent running car.
77 Macho Power Wagon LWB factory 440 70 Coronet 440 N code 3 speed
