Re: Exhaust drone (Magnum)
[Re: Mr.Yuck]
#490533
10/07/09 01:33 PM
10/07/09 01:33 PM
Posts: 805 San Francisco Bay Area
MrAngry
I have a JBA system on mine and suffer from the same drone problem... my solution... I'm back to stock.
Question though - are you running resonators?
Never trust a pretty girl... or a lonely midget.
[Re: Mr.Yuck]
#490534
10/07/09 02:17 PM
10/07/09 02:17 PM
Posts: 1,601 Hatfield,Pa.
bigD
Hatfield,Pa.
Check to see if your system has any resonators on it.I had 40 flows and no resos,3"x 16" rolled tips on my 08 charger R/T, TONS of drone . Added Blastin bobs 2&1/2" glasspack resos and 4" DW tips.Now its wife and long drive friendly,sounds good at idle/startup & BA at WOT.D
2015 Chrysler200s,2008 Charger R/T R&T,1999 Dakota R/T,1999 Viper ACR,1968 Charger R/T.
[Re: stumpy]
#490537
10/08/09 07:08 AM
10/08/09 07:08 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
How big and what kind of tips does it have?
not sure looks at least 2.5 maybe 3" w/ the big borla tips...they seem to be baffled.
[Re: Mancini Racing]
#490538
10/08/09 07:10 AM
10/08/09 07:10 AM
Mr.Yuck
Brookeville, Md
We have a Corsa system on our 2008 Charger Daytona development vehicle.
It's drone free even with long-tube headers.
With the 5.7L HEMIs and MDS, you have to be careful on the type of cat-back exhaust you put on these cars.
The other alterantive is eliminate the MDS with a a Diablo Predator hand-held tuner but your MPGs may suffer.
The system is designed for the car, so I'm guessing it's ok. I do plan on buying the tuner. It has settings from econ to performance.
[Re: MrAngry]
#490539
10/08/09 07:11 AM
10/08/09 07:11 AM
Mr.Yuck
Brookeville, Md
Is there room? the mufflers are at the tail end of the car. The Borla tips look like they could be baffled. I'm not looking at replacing the entire system. I was thinking of just a muffler swap.
[Re: Mr.Yuck]
#490540
10/08/09 09:17 AM
10/08/09 09:17 AM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
Are there any lengths of exhaust pipes that are 55 to 75 inches long? If so, put a resonator in the middle. If for some reason you can't use a resonator it is also possible to kill a drone noise with a T-stub, which is a dead end length of pipe off a T junction Someone in the family or your group of friends good at math? Have them read: http://www.audioholics.com/education/acoustics-principles/helmholtz-resonant-absorberif you look at the intake of the new Ford 6.2 V8 you will see T-stubs in use
[Re: Mr.Yuck]
#490541
10/08/09 02:14 PM
10/08/09 02:14 PM
bigD
Hatfield,Pa.
Does your system have a pair of mufflers(or suitcase muffler) ahead of the rear axle assmembly as well as mufflers(resonators)at the rear? The previous owner could have deleted the center muffs to get a more agressive exhaust tone. Also,the preditor can shut off the mds ,but you will still have drone at certain speeds/rpms. D,
[Re: bigD]
#490542
10/08/09 02:30 PM
10/08/09 02:30 PM
Mr.Yuck
Brookeville, Md
yeah I think it has all 4. I thought the mufflers were aft but those are resonators. Jeesh 4 mufflers and still a drone.
