what does this mirror fit??? #489850
10/06/09 04:38 PM
10/06/09 04:38 PM
DELAWARE
TONY_DAGOSTINO Offline OP
DELAWARE
i got this mirror from a guy who worked in the newark delaware assembly plant from the early 1960s up til about 2000
i bought some parts from him and included in the parts was a mirror.
at first glance the mirror looked to be the 67-75 most A + B body standard non remote mirror, but upon closer inspection it has a tapered screwhole at the mirror head base, therefor eliminating the use for a stud under the mirror, which every other mirror i have seen this style had, + i have had many of them
Re: what does this mirror fit??? [Re: TONY_DAGOSTINO] #489851
10/06/09 04:40 PM
10/06/09 04:40 PM
DELAWARE
DELAWARE
ANOTHER PIC
Re: what does this mirror fit??? [Re: TONY_DAGOSTINO] #489852
10/06/09 06:27 PM
10/06/09 06:27 PM
bigblockSfury Offline
I would have to look to be sure however that looks a lot like the mirror on my 64 sport fury. I remember being P.O. about how difficult it was to get at that screw. I would look before posting however the car is in storage 2.5 hours away.
Re: what does this mirror fit??? [Re: bigblockSfury] #489853
10/06/09 06:29 PM
10/06/09 06:29 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
I seem to remember hearing about (or seeing) an over-the-counter right side mirror that could be mounted without removing the door panel. Perhaps that is it.
Re: what does this mirror fit??? [Re: TONY_DAGOSTINO] #489854
10/07/09 10:13 AM
10/07/09 10:13 AM
DELAWARE
DELAWARE
ive taken mirrors off of 64 plymouths before and the mirror on those had a stud sticking down, not a 2nd screwhole
also, this was "removed" from an assembly plant, not a parts depot so i dont believe it would have been an addon mirror
i believe c-body cars were made at this plant so maybe its for a c-body that im not very familiar with ???
thanks for the input
tony
Re: what does this mirror fit??? [Re: TONY_DAGOSTINO] #489855
10/07/09 09:36 PM
10/07/09 09:36 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Could it have destined for over the counter, but then mispackaged with production line parts. Then because it was wrong/RMA/discrepant parts, it found it's way out of the plant. Just a theroy...
Re: what does this mirror fit??? [Re: autoxcuda] #489856
10/08/09 10:03 AM
10/08/09 10:03 AM
DELAWARE
DELAWARE
good idea, but
assy line parts werent individually packaged, they were in master packs,
ie: a group of 36 in 1 box
parts could be wrapped for protestion, but not individually boxed as they needed to be easily accesable for assy line workers to grab + install on the car
