727 upshifts, what to do next?? #489542
10/06/09 01:02 AM
10/06/09 01:02 AM
Eugene, Oregon
minivan Offline OP
minivan  Offline OP
Eugene, Oregon
727 behind my 67-440..
I have adjusted the kickdown linkage everyway I can and the tranny still shifts 1-2-3 way to fast for my liking.. Usually into third gear before I get through the intersection.. I have 294 rear end gears so you would think it would stay in 1st and 2nd a little longer... Shifts way to early at WOT also ( no tach so I can't say exactly)
What do I do next?? Valve body work?? New governor?? Any help....
Re: 727 upshifts, what to do next?? [Re: minivan] #489543
10/06/09 01:17 AM
10/06/09 01:17 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
It's the valve body.
Re: 727 upshifts, what to do next?? [Re: 451Mopar] #489544
10/06/09 04:58 AM
10/06/09 04:58 AM
ont, canada
K
kenny b Offline
kenny b  Offline
K
ont, canada
Could also be a stuck governor on the tailshaft. In the book on rebuilding 727's there is a testing procedure using pressure gauges.
Kenny B
Re: 727 upshifts, what to do next?? [Re: minivan] #489545
10/06/09 04:05 PM
10/06/09 04:05 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Disconnect the linkage from the top lever on the trans and operate it by hand, the lever should have increasing spring resistance as it is moved rearward and should hit a hard stop both for and aft. If the lever feels soft against the stops, the shaft might have broken loose from its internal cam. The pic below shows the weld that often breaks.
Re: 727 upshifts, what to do next?? [Re: John_Kunkel] #489546
10/06/09 07:22 PM
10/06/09 07:22 PM
For my information does that lever you show in the pic have an internal spring? I felt no resistance on mine and added an external spring. It shifts perfect now. Before that it would over-center and bind. thanks
Re: 727 upshifts, what to do next?? #489547
10/06/09 10:16 PM
10/06/09 10:16 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
That level pushes a spool valve that has a very light spring on it... It should reach a solid stop in the forward direction when the bent tab contacts the limit screw.. It should have light spring tension then hit solid in the rearward direction when the spool bottoms in it's bore..
Re: 727 upshifts, what to do next?? [Re: 1_WILD_RT] #489548
10/06/09 11:54 PM
10/06/09 11:54 PM
Eugene, Oregon
minivan Offline OP
minivan  Offline OP
Eugene, Oregon
I will check mine and respond back here.
