help with fan please #487529
10/03/09 10:38 PM
10/03/09 10:38 PM
ireland
mitchdublin Offline OP
ireland
Hi, I have no fan on the car i bought. I want to put on a clutch fan. I only have 3 and 3/4" clearance between waterpump pulley and rad.
Any recommendations?
Re: help with fan please [Re: mitchdublin] #487530
10/04/09 06:03 AM
10/04/09 06:03 AM
Franklin Co. Illinois
runinonmt Offline
runinonmt  Offline
Same problem on my Duster when I installed the new aluminum radiator. The Hayden 2765 fan clutch is what you need. I can't remember the year or model, but it is for a Jag. Got mine at O'Reilly's. Fan from the Mopar clutch bolts right on and a bushing is included to fit the water pump shaft. Found it. 1990 Jag XJ6. Try Rock Auto if you can't get any help locally. Good luck.
Ron
In sixty-five I was seventeen and running up one-o-one I don't know where I'm running now, I'm just running on Jackson Browne-Running On Empty
