Need help with block ID #487455
10/03/09 09:12 PM
10/03/09 09:12 PM
S.E. Missouri
AeroMonte Offline OP
S.E. Missouri
I found an engine block that is supposed to be a 360 that has been fully machined and ready for assembly. The price is right and I need to know foor sure what it is. There is a casting number on the block above the starter 3614230-2. There are no other raised castings that I could see. The block is wrapped in plastic and coated with grease in the corner of the guys shop. Is this enough info to ID what this block is? I want a 360 to put in my sons 79 stepside 4wd to replace the 318 it has now.
Re: Need help with block ID [Re: AeroMonte] #487456
10/03/09 09:15 PM
10/03/09 09:15 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Thats an early 400.. Could be the cold weather block, not what your looking for but probably worth picking up...
Re: Need help with block ID [Re: AeroMonte] #487457
10/03/09 09:16 PM
10/03/09 09:16 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
3614230 is a 400 big block...
Re: Need help with block ID [Re: OzHemi] #487458
10/03/09 09:25 PM
10/03/09 09:25 PM
S.E. Missouri
S.E. Missouri
It's just a block with main caps. No other internal or external parts but I can have it for $100
Re: Need help with block ID [Re: AeroMonte] #487459
10/03/09 09:31 PM
10/03/09 09:31 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Bring it home... Just the thing for a future stroker project...
Look at the main webs.. They are all good but the best ones have thicker main webs... I borrowed these pictures from 440 Source..
Normal web
Thick web..
Re: Need help with block ID [Re: 1_WILD_RT] #487460
10/03/09 09:34 PM
10/03/09 09:34 PM
S.E. Missouri
S.E. Missouri
Thanks, I'll check on it.
