Trans question #487452
10/03/09 09:06 PM
10/03/09 09:06 PM
New Lenox il.
CARMAN Offline OP
CARMAN  Offline OP
New Lenox il.
I have a 98 ram van 1500 with a overdrive trans the other day the overdrive developed a whine.Has anybody ever taken one apart or is there any books out there for the o.d unit.I have rebulit 727s before.
Re: Trans question [Re: CARMAN] #487453
10/03/09 09:42 PM
10/03/09 09:42 PM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
The 518 based trans have a history of O/D issues from poor lubrication to the rear of trans, which has probably damaged the O/D planetery set, causing the whine. There is a modified intermediate shaft that is avalible that has larger lube holes to remedy this. Also, there is a spring loaded clutchpack that requires a special tool and a press to compress. I'm sure people will ring in on how they R&Red the spring, but be warned that is has between 650-800lbs of holding pressure. Other than that, the O/D units aren't that bad. I don't know of a manual, but I'm sure one of the trans rebuilders sell them.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: Trans question [Re: Evil Spirit] #487454
10/03/09 11:05 PM
10/03/09 11:05 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
There is probably an ATSG manual for the trans. Try here first: http://atsg.com/cart/
