Very Low Fuel Pressure #487384
10/03/09 07:02 PM
10/03/09 07:02 PM
Los Angeles, CA
Mobarge Offline OP
Mobarge  Offline OP
Los Angeles, CA
Noticed something interesting today during a nice, leisurely morning drive.
I have a gauge on my Russell fuel feed to my carb. The gauge is about six months old. At idle (900 RPM), the gauge reads that my fuel pressure is 1 PSI. When I wrap up the RPMs (to around 3,000), it reads 3 PSI, so I know the gauge works.
The car runs and idles fine... although, I did notice it wanting to peter out when I landed on it.
Bad fuel pump? I am running an Edelbrock mechanical fuel gauge, 120 GPH at 6 - 8 PSI (supposedly). Pump is a few years old. Could it be the diaphragm?
'71 SSP - SOLD!
Re: Very Low Fuel Pressure [Re: Mobarge] #487385
10/03/09 07:03 PM
10/03/09 07:03 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Worn pushrod maybe?
Re: Very Low Fuel Pressure [Re: ademon] #487386
10/03/09 07:05 PM
10/03/09 07:05 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
pull the pump and check the length, i forgot how long it should be someone will chime in, but if its worn you will also see it concaved usually on the cam end.
Re: Very Low Fuel Pressure [Re: ademon] #487387
10/03/09 07:27 PM
10/03/09 07:27 PM
Happy Birthday RapidRobert  Offline
My new one is 3&7/32".
Re: Very Low Fuel Pressure [Re: RapidRobert] #487388
10/03/09 08:28 PM
10/03/09 08:28 PM
Los Angeles, CA
Mobarge Offline OP
Mobarge  Offline OP
Los Angeles, CA
Dumb question, but how do you pull the pump pushrod out? It's a 413 with about 2,000 miles on it.
'71 SSP - SOLD!
Re: Very Low Fuel Pressure [Re: Mobarge] #487389
10/03/09 08:35 PM
10/03/09 08:35 PM
Missouri
MY340 Offline
MY340  Offline
Missouri
A leak/air entering in the fuel line will also cause low fuel pressure. On my old Duster mine was back by the fuel tank and the hose didn't leak fuel. It gave me fits for about 3-4 weeks before I figured it out.
1970 FE5 Duster 360/904/3.91's SOLD 1973 TB3 SpaceDuster 340/4spd/4.10's SOLD Moparless for now but when the opportunity is right I'll have another one.
Re: Very Low Fuel Pressure [Re: MY340] #487390
10/03/09 08:43 PM
10/03/09 08:43 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
A hard gremlin to chase.. The fuel line is sucking from there and will not leak but allow air to enter from the suction of the fuel pump.. Your looking for fuel leaking when its air being sucked in....
Re: Very Low Fuel Pressure [Re: Mobarge] #487391
10/03/09 08:51 PM
10/03/09 08:51 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
You pull the fuel pump, and there is a pipe plug just under it, remove that and the push rod will slide out.
As said, a hose sucking air could be an issue too...check all the stuff in the engine bay and the bit at the sending unit too just incase.
Re: Very Low Fuel Pressure [Re: OzHemi] #487392
10/03/09 09:40 PM
10/03/09 09:40 PM
Lapeer, MI.
todd440 Offline
todd440  Offline
Lapeer, MI.
I've noticed a rash of worn pushrods lately, probably due to the lack of zinc in the oil. I have about 10 on the bench right now, most are worn, 1 of them a full .250 short of a new one. Look for a worn or cupped tip.
