Big block oil pump drive bushing tool #486908
10/03/09 03:02 PM
10/03/09 03:02 PM
Connecticut
biginchmotor Offline OP
Connecticut
A friend of mine called me the other day and asked me if I had ever changed a oil pump drive bushing in the car, I said no. He saw a tool in an old factory service manual but can not find the tool anywhere. He told me the tool was made by Wilson? I told him I would post it here to help him find some info. If anyone can help I will pass it along to him. Thanks John.
Re: Big block oil pump drive bushing tool [Re: biginchmotor] #486909
10/03/09 03:05 PM
10/03/09 03:05 PM
Lapeer, MI.
todd440 Offline
todd440  Offline
Lapeer, MI.
It's a miller tool. I have one in the barn, I'll look at the part number. The number is also listed in the service manual. Same one for small block and big block.
Re: Big block oil pump drive bushing tool [Re: todd440] #486910
10/03/09 03:09 PM
10/03/09 03:09 PM
Connecticut
Connecticut
That would be great. He is trying to do this in the car, thanks.
Re: Big block oil pump drive bushing tool [Re: biginchmotor] #486911
10/03/09 03:09 PM
10/03/09 03:09 PM
NY
twodoorpost Offline
twodoorpost  Offline
NY
Re: Big block oil pump drive bushing tool [Re: twodoorpost] #486912
10/03/09 03:12 PM
10/03/09 03:12 PM
Connecticut
Connecticut
Thanks for the help...John.
Re: Big block oil pump drive bushing tool [Re: biginchmotor] #486913
10/03/09 03:19 PM
10/03/09 03:19 PM
Lapeer, MI.
todd440 Offline
todd440  Offline
Lapeer, MI.
3052 is the remover, c-3053 is the installation tool.
Re: Big block oil pump drive bushing tool [Re: todd440] #486914
10/03/09 03:21 PM
10/03/09 03:21 PM
Lapeer, MI.
todd440 Offline
todd440  Offline
Lapeer, MI.
Re: Big block oil pump drive bushing tool [Re: todd440] #486915
10/03/09 06:16 PM
10/03/09 06:16 PM
The correct Miller tool threads into the bushing & in the car would kick out some shavings. I'm wondering if a slde hammer w an L shaped end would get it out of there witout any debris.
Re: Big block oil pump drive bushing tool [Re: RapidRobert] #486916
10/03/09 08:29 PM
10/03/09 08:29 PM
South Jersey
kruger Offline
Yours Too!
kruger  Offline
Yours Too!
South Jersey
I just use a long rod bent flat at the end with an old 3/8's socket for a slide and a screw driver handle pressed on the other end.
Never made a big effort to find the burnishing tool till I saw the pic in AndyF's book.
That tool would take the big "ooops" factor away
Re: Big block oil pump drive bushing tool [Re: kruger] #486917
10/03/09 10:14 PM
10/03/09 10:14 PM
IN
ahy Offline
ahy  Offline
IN
I had a bushing just pressed in without the tool on a B engine. I had the engine apart for another reason and found a near miss on the bushing. It was loose in the block and almost spinning and tight on the distributor drive shaft. The shaft was scored. I got a new shaft and new bushing and installed it with the correct tool. Some people have gotten lucky but I would never do a bushing again without it. The bushing was designed to be pressed in place and burnished to size with the tool.
Re: Big block oil pump drive bushing tool [Re: biginchmotor] #486918
10/04/09 07:18 AM
10/04/09 07:18 AM
Lapeer, MI.
todd440 Offline
todd440  Offline
Lapeer, MI.
If the block has been thermal cleaned, they shrink and are not a good press fit any more. I can usually pop them out with easy, and by hand.
