Re: what is faster big block chevy or mopar?
[Re: dusturbd340W5]
#486291
10/02/09 10:51 PM
10/02/09 10:51 PM
Posts: 452 Monrovia, So-Cal, USA
racerhog
Well...I'm not sure...... But up to about 1976. Mopar for me..... But after that, it started getting mixed up....
Bob(Cowboy)Hogan Monrovia So-Cal
[Re: moretoys]
#486294
10/03/09 01:40 AM
10/03/09 01:40 AM
Posts: 1,949 land of 10,000______'s
BDS871Cuda
Here is my chevy would make more power.There is just so much more available parts for the chevy.Now lets make a better comparison.396 chevelle vs a 383 r.r.close to the same advertised h.p..car weight is close.What you think??You want to compare the ls6,A closer rival would be a max wedge.Even A better comparison that I would like to see is an apple- apple test.take a 440 and a 454,build them the same.Comp. ratio,cam size,intake,carb, etc.basicly same modification to both engines,I think the mopar would come out on top.Anyone board with some engines laying around
This guy had some motors laying around! Remember this rightup about 8 years ago. And for the record the Buick used T/A heads and intake, so the Buick doesn't count. All the rest used Edelbrock heads and intake. They all had Hooker headers and the same carb and same MSD. Cams and comp. were also real close. The 440 was the smallest C.I. but made the same H.P. as the Chevy at the top of H.P. numbers. The 440 was the king of TQ. for all the motors. Steve Brule did these motors up at Wes-tech (I think thats the name of the shop) The 440 made 535 HP at 5300 and 582 ft lbs. at 4100 RPM's. Talk about a low rpm street monster!!!
So, YES the Mopar is faster than the Chevy. (In this case)
Snap your neck, mega G-force launch, is all I want!
[Re: dodgeboy11]
#486296
10/03/09 04:50 AM
10/03/09 04:50 AM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
A question like this, gets no real answer, because someone knew someone, who had a fast whatever it might have been.....but when it comes down to it, cylinder heads are the answer. Given the same cubic inches, the same weight car and similarly prepared combos, the rectangular port Chevy, beats the wedge Mopar everytime. You can't compare stock and super stock, because of all the factoring and weight breaks. And as much of a Mopar guy as I am, it is not hard to see the advantage a rect port Chevy head has over a Mopar wedge.
Monte
[Re: Monte_Smith]
#486297
10/03/09 06:38 AM
10/03/09 06:38 AM
Posts: 6,446 NJ-USA
HPMike
NJ-USA
Monte
well said and end of story, really. Even the oval port head is a better piece than the conventional wedge. In "original" configuration, the Mopar stuff had a better quality of materials from a durability standpoint, but the comparisons pretty much end there.
Let's not forget folks how much reverence the Mopar camp gave the Chevy Rat. If you get the chance to see the Ball Stud Hemi, it was pretty much a copy of the design.
MB
[Re: B5 Bee]
#486298
10/03/09 07:05 AM
10/03/09 07:05 AM
Posts: 4,862 the frozen wastes...
Pale_Roader
Swears too much
Swears too much
1969 Chevrolet Corvette Stingray LT2 454 V8 465 ** 10.6 132 MT
4th on the list, is this supposed to be a real car from 1969 or some ones fantasy?
Memory is not as long as it needs to be on this one, but wasn't the 'LT2' another name for the L88 in 69? That '454' might be a typo and should say 427?
I could see an L88 Vette being that high up on that list.
And on that Edelbrock engine build up. I would have given Chevy the easy win on that one before reading it. Edelbrock is essentially a Chevy company that decided it could make money on other brands if they threw some stuff into the market. I still think the Edelbrock head for the 440 is a poor design in some important ways, AND being a Chevy company i would assume they had a lot more time to play around with improving the BBC, and more total design time in that head. Also factor in the bajillions ov well known, proven combos for the 454, compared to the (maybe) hundreds ov well known, proven combos for the 440, and i would have assumed the Mopar would have had its ass handed to it.
I think that shootout went a long way to proving how superior the BBM is to the BBC. Both were designed 45 years ago, and the builds didn't stray too far, so i think it proves the Mopar was closer to modern thinking than the Chevy. If Mopar had bothered with quench and had even the most primitive balancing specs back then, it would have been a legend on par with the hemi.
I was very surprised at how well the Mopar did. Goes to show how easy it is to make a Mopar fly. Just leave the junk antique pistons out ov the build and balance the damn thing!
[Re: Monte_Smith]
#486299
10/03/09 09:31 AM
10/03/09 09:31 AM
Posts: 568 Ky
moparmafia
Ky
i know that on paper it looks like the chevy will always win because of superior head flow. i know they are getting more head flow than most all of our aftermarket indy, edelbrock heads. but it seems the mopars always run with them at the track. is it because the rest of the head has a better design, like combustion chamber, high velocity ports that create more torque than chevy? and better valve degree?
Monte
[Re: moparmafia]
#486300
10/03/09 09:58 AM
10/03/09 09:58 AM
Posts: 3,619 Norwich CT USA
Defbob
Norwich CT USA
I had a 454 BBC with ported ZL1 heads on it. It had a big roller cam, but it ran a high 10 in a 3100lb Nova with a bad plug wire. (motor was lent out while my car was being finished)
stock rods, TRW pistons, stock crank, mildly ported ZL1 heads, Victor intake, 1087cfm DP, 13.5:1 comp, .685 roller.
But, now there are FAST Mopar Wedges cars running 11.00's and not with slicks and ladder bars.
[Re: Defbob]
#486301
10/03/09 10:59 AM
10/03/09 10:59 AM
Posts: 4,761 Holland MI Ottawa
2boltmain
Holland MI Ottawa
An LS-5 454 had a simliar build to a 440 magnum. Both engines used 10:1 ish compression, both engines had hyd cams and both engines used non holley carbs (LS-5 used a big Q jet?) LS-5 made 365hp and 440 mag made 375. The 440 was much much faster in the 1/4mile. The Chevy is like our hemi- It needs cam and compression to shine. Wedge motors ran hard with mild specs. (Mild compared to big bock chevies)
Keep old mopars alive.
[Re: b1dartsport]
#486305
10/06/09 05:08 PM
10/06/09 05:08 PM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
Back in the late 60's my friend Ron Kukuruda had a 64 belevedere with a 318. We bought a bone stock max wedge engine that was in a mopar crate from a speed shop in columbus ohio. This was an all steel car, with a mostly stock push button 727 and a 3000 converter. I think the car had 9" M & H cheater slicks on it also. I was with Ron on many of nights on the street & this car never even came close to losing to any big block chevy. When we finally got the car to the strip & took the covers off the cast iron headers the thing went mid 11s. Most of the people who ran at keystone & Pittsburgh (PID) know of this car which was bone stock down to the factory head gaskets.
Randy,referr back to my early post about mopar racers around Pgh. on this thread.Our Mopar racers are like our Pgh Steelers and our Penguins.Our GM and Ford guys follow the Pgh Pirates.Ron and many others have made their mark.
[Re: CrAzYMoPaRGuY]
#486308
10/06/09 06:00 PM
10/06/09 06:00 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
! As for the question, the answer is EASY. On a MoPar forum, the MoPar was faster for sure from the factory. On a Chevy forum, the Chevy was faster for sure from the factory. What do I win?
Thats just what I was going to say. But to compare the bigblock wedge to the bigblock Chevy in stock contition you would have to use the Max Wedge as that was the baddest wedge for Mopar right from the factory. Ron
[Re: cheapstreetdustr]
#486309
10/06/09 06:24 PM
10/06/09 06:24 PM
B G Racing
Eighty Four, PA
Bob.. you left out the E.A.G.L.E.S on purpose? cheapst.
You mean that team that Mad Dog Mikael Vick plays for? If they ever get to PGH,I'll sic my dog Maxinus on him.
