Imperials and C-bodies - #485027
10/01/09 10:04 AM
10/01/09 10:04 AM
Tennessee
WyleECoyote Offline OP
Tennessee
Are Imperials considered C-body or are they there own stand alone class? 1972 in particular.
Thanks,
Ron
Wile E. Coyote
Super Genius, Lover of FCA US LLC Products
68 Road Runner (440 4-spd), 71 Superbee (383 slap), 71 Charger 500 (383 4-spd wA/C 1of 182), 72 Imperial, 74 Charger SE (440 sunroof), 84 D350 Crew-cab Dually (440), 75 D300 Dually Tandem (318 4-speed)
Re: Imperials and C-bodies - [Re: WyleECoyote] #485028
10/01/09 10:08 AM
10/01/09 10:08 AM
Bloomington, Illernoise
cptn60 Offline
cptn60  Offline
Y body. Commonly accepted as a C-body as I understand it.
This space available for rent
Re: Imperials and C-bodies - [Re: WyleECoyote] #485029
10/01/09 10:12 AM
10/01/09 10:12 AM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
Some of them are D-bodies but can't remember which ones. Imperials have LOTS of Imp-only parts, so if you're buying one be aware of that.
Parts I seek: driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set 16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better. 69-73 C-body caliper brackets and/or splashields Send a PM.
Re: Imperials and C-bodies - [Re: Fury Fan] #485030
10/01/09 10:33 AM
10/01/09 10:33 AM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
if i remember right, imps were y bodies until 1970 when they were changed to c bodies. there was no physical change between these years. i used to have a 69 imp, try finding disc brake pads for early 69 and earlier imps. late 69 and newer pads are easily found.
Re: Imperials and C-bodies - [Re: WyleECoyote] #485031
10/01/09 11:20 AM
10/01/09 11:20 AM
Southern CA
Colin Frolick Offline
Southern CA
i have a '71... the front clip is different than a c-body polara or fury. look in the fsm the control arms, spindles, and subframe are different, and the torsion bars are longer. 5 x 5" wheel bolt circle. CV joints on the driveshaft. i ordered a c-body front sway bar from firm feel and it was totally different, sent it back with my original and they bent me up a custom 1-1/4" bar that fits perfectly. c-body shocks fit, tti c-body headers fit. 1969-74 were the same car probably? hope this helps
Re: Imperials and C-bodies - [Re: WyleECoyote] #485032
10/02/09 01:32 PM
10/02/09 01:32 PM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
Your '72 is a C body, as are all '67-'74 Imps. No such thing as a "Y" body, Y is the code for MAKE (C for Chrysler, D for Dodge, P for Plymouth, W for Coronet, etc.)
Thanks,
Ron
Re: Imperials and C-bodies - [Re: @#$%&*!] #485033
10/02/09 02:48 PM
10/02/09 02:48 PM
St. John's Newfoundland
440newport Offline
440newport  Offline
Not really. I've usually heard them considered D bodies
67-68 Is still it's own animal, almost nothing interchanges with a C body, body, brakes,frame, suspension even wheel bolt pattern is all different.
'69-73 are similar to C bodies, but have a longer wheel base with a different front frame and longer T bars. Still have their own brakes and bolt pattern. Similar body and interior though.
'74-75 are pretty much the same as C bodies. They lost their uniqueness by then, the 75 Imperial styling was then used for 76-78 New Yorker.
Re: Imperials and C-bodies - [Re: 440newport] #485034
10/02/09 04:06 PM
10/02/09 04:06 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I agree 69 to at least 71 the front ends are different.Just try and find an Idler arm for a 70 71 Imp.One guy bought one on the 70 Imps that I had just for the Idler and some other parts for his 71.New idler arm was 500 bucks.Lots more than a normal C body.I owned like 6 Imperial and the 66 was probally my favorite.It was total black and looked like a funeral car.Rocky
Chrysler Firepower
Re: Imperials and C-bodies - [Re: therocks] #485035
10/04/09 08:46 AM
10/04/09 08:46 AM
Tennessee
Tennessee
Thanks everyone!
I have a 72 Imperial 2-door hdtp and no other C-bodies. I have a complete 1970 6-pack engine I'd like drop in a 70 Newport (painted like a Hurst) or a 70/71 Fury made into a Sport Fury. Owning the Imperial and no C-bodies, I didn't know much about the crossover between the two since I'm headed into the Newport/Fury world.
Thanks for the info!
Wile E. Coyote
Re: Imperials and C-bodies - [Re: 440newport] #485036
10/04/09 09:21 AM
10/04/09 09:21 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
I guess this could be debated ,if you check all parts books up to 1975,body plates list all Imperials as Y body. Also,the 73 Imperial has a 126.5" wheelbase where as the rest of the Chrysler line is 123.5".So it actually is one of it's own.
Re: Imperials and C-bodies - [Re: @#$%&*!] #485037
10/08/09 05:07 AM
10/08/09 05:07 AM
Turneffe
BJohnson Offline
BJohnson  Offline
Turneffe
Thanks,
Ron
Imperial was a Y body in 1972.
