68-70 B body trunk extensions #478998
09/25/09 08:11 AM
09/25/09 08:11 AM
Maryland, USA,
satgtx Offline OP
satgtx  Offline OP
Maryland, USA,
Can you change thrunk extensions with out harming damaging the quarter panels? or will it require some work on quarter and repaint?
Re: 68-70 B body trunk extensions [Re: satgtx] #478999
09/25/09 08:55 AM
09/25/09 08:55 AM
3
340dart4spd Offline
Parts Problem
340dart4spd  Offline
Parts Problem
3
If your trunk ext are rotted/there is a high probability your quarters have rot also..
Re: 68-70 B body trunk extensions [Re: 340dart4spd ] #479000
09/25/09 09:17 AM
09/25/09 09:17 AM
arizona, usa
lokalik Offline
lokalik  Offline
arizona, usa
your outter wheel well my have rot also
Re: 68-70 B body trunk extensions [Re: lokalik] #479001
09/25/09 11:09 AM
09/25/09 11:09 AM
Toronto, Canada
dirtybee Offline
dirtybee  Offline
Toronto, Canada
i agree with previous comments but when i repaired the whole belly of my 70 bee, i could not afford to do quarters at the same time. i replaced the trunk pan (2 piece) and the trunk extensions, and the outer wheelhouses without replacing the quarters. i did have to redo the bondo around the wheel opening, as the welding burned away the original bondo.
Re: 68-70 B body trunk extensions [Re: dirtybee] #479002
09/25/09 01:10 PM
09/25/09 01:10 PM
O
OLD318 Offline
OLD318  Offline
O
How could you replace the outer wheel house
structure without removing at least a portion
of the quarter panel?
Did you just replace the outer wheel lip with a patch panel?
Re: 68-70 B body trunk extensions [Re: OLD318] #479003
09/25/09 01:12 PM
09/25/09 01:12 PM
3
340dart4spd Offline
Parts Problem
340dart4spd  Offline
Parts Problem
3
on his back!!!
