Slip yoke fit??? #478446
09/24/09 05:48 PM
09/24/09 05:48 PM
Newfoundland
Crocker Offline OP
Crocker  Offline OP
Newfoundland
How tight should the slip yoke fit in the back of an A833? Is there a tolerance check? Also If I need a new one, what's out there? Billet?? What I need is for a 7290 u joint and an A833, All I see listed is for a 727...
Re: Slip yoke fit??? [Re: Crocker] #478447
09/24/09 08:05 PM
09/24/09 08:05 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
727 and 833 use the same yoke.
Re: Slip yoke fit??? [Re: 62maxwgn] #478448
09/25/09 08:53 AM
09/25/09 08:53 AM
Newfoundland
Crocker Offline OP
Crocker  Offline OP
Newfoundland
Thanks... Anyone have an idea about what's considered loose? Side movement?
