Bobweight Question on Rotating Assy. #477789
09/23/09 08:07 PM
09/23/09 08:07 PM
MNobody Offline OP
MNobody  Offline OP
Looking at a Scat rotating assembly, listed as 1734-1750 bobweight is that heavy, light or what's average? Thanks.
Re: Bobweight Question on Rotating Assy. [Re: MNobody] #477790
09/23/09 08:17 PM
09/23/09 08:17 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
Must be a SB, it's impossibly light for BB.
Re: Bobweight Question on Rotating Assy. [Re: 64Post] #477791
09/23/09 08:21 PM
09/23/09 08:21 PM
MNobody Offline OP
MNobody  Offline OP
Sorry, it's a 408 assy.
Re: Bobweight Question on Rotating Assy. [Re: MNobody] #477792
09/23/09 08:32 PM
09/23/09 08:32 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
That's pretty light.
For a comparison - My stock rod, KB107 piston, 360 comes in at about 2100.
Should be a quick revving engine.
Re: Bobweight Question on Rotating Assy. [Re: RobX4406] #477793
09/23/09 08:47 PM
09/23/09 08:47 PM
MNobody Offline OP
MNobody  Offline OP
That's what i was hoping to hear I found an unbalanced kit for 1060.00
Re: Bobweight Question on Rotating Assy. [Re: MNobody] #477794
09/23/09 09:14 PM
09/23/09 09:14 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
thats pretty light just for comparision my 416 sb with scat H beams custom diamond slugs that are real short with a compression height of 1.225 and chevy pins had a bob weight of 1891
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Bobweight Question on Rotating Assy. [Re: dusturbd340W5] #477795
09/23/09 09:29 PM
09/23/09 09:29 PM
MNobody Offline OP
MNobody  Offline OP
This is the kit i'm looking at.
Chrysler Small Block 360 Main, Series 9000 Cast, I-Beam rods with 7/16" Cap Screws
Description SB CHRYSLER 360/408
Crankshaft 9-360-4000-6123-2123
Rods 2-ICR6123-2124
Pistons FLAT TOP
Comp. Ratio 58cc-12.1, 64cc-11.3, 70cc-10.8
