71 Dodge Truck - help repair leak in gas tank!
#477721
09/23/09 04:13 PM
09/23/09 04:13 PM
Posts: 1,377 Tennessee
WyleECoyote
Tennessee
As you know, the gas tank is behind the seat. The tank sprung a leak while driving; my brother is driving here to Knoxville from Charleston. Are there any products available at auto parts stores to use on a wet area that will seal it?
Wile E. Coyote Super Genius, Lover of FCA US LLC Products ************* 68 Road Runner (440 4-spd), 71 Superbee (383 slap), 71 Charger 500 (383 4-spd wA/C 1of 182), 72 Imperial, 74 Charger SE (440 sunroof), 84 D350 Crew-cab Dually (440), 75 D300 Dually Tandem (318 4-speed)
Re: 71 Dodge Truck - help repair leak in gas tank!
[Re: CYACOP]
#477723
09/23/09 08:25 PM
09/23/09 08:25 PM
Posts: 6,167 Maryland
GO_Fish
Maryland
That, or siphon the tank down below the leak, then dry and clean it and mix some two part epoxy. Just beware that if it's rust, you'll be back in there again when the next pin hole starts.
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
