HELP !!!! STEERING COUPLER COVER #476895
09/22/09 08:00 PM
09/22/09 08:00 PM
Dennispsalm91 Offline OP
Ok ive been working on this flippin thing for an hour. What is the secret for getting the cover to stay on the coupler ?? ive tried a clamp, im ready to pull out my hair, 3 beers later still cant get in to stay. Any help here would be appreciated
Re: HELP !!!! STEERING COUPLER COVER [Re: Dennispsalm91] #476896
09/22/09 08:43 PM
09/22/09 08:43 PM
South Jersey
kruger Offline
Yours Too!
kruger  Offline
Yours Too!
South Jersey
Is it this type of coupler?
If it is,grease it then just bend those tabs over(downward of course).
Re: HELP !!!! STEERING COUPLER COVER [Re: Dennispsalm91] #476897
09/22/09 08:46 PM
09/22/09 08:46 PM
LEE, MASS
TOMRR Offline
TOMRR  Offline
LEE, MASS
Re: HELP !!!! STEERING COUPLER COVER [Re: TOMRR] #476898
09/22/09 08:47 PM
09/22/09 08:47 PM
N.E. Ohio
K
KillerBee Offline
KillerBee  Offline
K
N.E. Ohio
Re: HELP !!!! STEERING COUPLER COVER [Re: TOMRR] #476899
09/22/09 10:01 PM
09/22/09 10:01 PM
Ive never seen that clip before. Is there somebody who sells them ? Ive bent over those tabs and they just wont stay around the coupler body.
Re: HELP !!!! STEERING COUPLER COVER [Re: Dennispsalm91] #476900
09/22/09 10:09 PM
09/22/09 10:09 PM
Cleveland, Ohio
northcoastmopar Offline
Cleveland, Ohio
A board member used to make those clips, I bought one a few years back. I don't think he makes them anymore.
The redesigned rubber cover looks pretty slick, you can get those at the link below -
http://www.steerandgear.peachhost.com/ct_CGchryslerremanufacturedmanualsteeringgears.htm
The factory design is a pita to seal.
Re: HELP !!!! STEERING COUPLER COVER [Re: Dennispsalm91] #476901
09/22/09 10:11 PM
09/22/09 10:11 PM
Hunt Valley, Maryland
1fastrunner Online work
1fastrunner  Online Work
I got mine from RT Specialties
Re: HELP !!!! STEERING COUPLER COVER [Re: 1fastrunner] #476902
09/22/09 10:29 PM
09/22/09 10:29 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
The trick to the stock cover is you do 95% of the bending & setting up of the tabs before you ever start to install the kit.. Get it so you need to work the tabs over the nubs on the coupler body then install it... After the cover is snapped into place a little careful work with a pair of Channel-locks & your good...
Re: HELP !!!! STEERING COUPLER COVER [Re: 1_WILD_RT] #476903
09/23/09 08:26 AM
09/23/09 08:26 AM
scratchnfotraction Offline
I do mine at the corners
pinch one corner the oposite corner then the other 2 corners
Re: HELP !!!! STEERING COUPLER COVER [Re: scratchnfotraction] #476904
09/23/09 12:54 PM
09/23/09 12:54 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
2 C clampS ( one at each side, wider side ) to keep cover on place and then HAMER the tabs.
The clip was a solution made on dealers service.
I made to fit it with wire straps LOT TIGHTENED though ( crossed throught the body ) since I made it on car. NOT EASY THOUGH
Re: HELP !!!! STEERING COUPLER COVER [Re: NachoRT74] #476905
09/23/09 04:49 PM
09/23/09 04:49 PM
I ordered the clips from R/T specialties, thanks guys for the input.
Re: HELP !!!! STEERING COUPLER COVER [Re: Dennispsalm91] #476906
09/23/09 05:49 PM
09/23/09 05:49 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
