wiw 48 plymouth street rod?
#476603
09/22/09 01:35 PM
09/22/09 01:35 PM
Posts: 17,861 albany ny
05dakota
albany ny
Re: wiw 48 plymouth street rod?
[Re: 05dakota]
#476604
09/22/09 01:37 PM
09/22/09 01:37 PM
05dakota
albany ny
info from seller"
REBUILT SWEET RUNNING 330 C.I. "HEMI" VINTAGE EDELBROCK INTAKE MANIFOLD EDELBROCK 4 BL. CARB BILLET PULLEYS CHROME ALTERNATOR CAST ALUMINUM VALLEY PAN "NEW" MSD DISTRIBUTOR AND COIL "NEW" HIGH PERFORMANCE PLUG WIRES WEIAND WATER PUMP STAINLESS FLEX HOSE COVERINGS ELECTRIC COOLING FAN ELECTRIC FUEL PUMP NEW COATED HEADERS ALL "NEW" DUAL EXHAUST WITH "H" BALANCER PIPE, hEAT SHEILDS IN CRUCIAL AREAS, CHERRY BOMB MUFFLERS, 4" STAINLESS EXHAUST TIPS. REBUILT TORQUE FLITE, AUTO TRANS WITH A MILD SHIFT KIT "NEW" TALL LOKAR FLOOR SHIFTER 12 BOLT REAR, NON POSI bODY AND SUSPENTION DETAILS: THIS IS A RARE BUISNESS COUPE WITH NO BACK SEAT AND THE SHORT 1/4 WINDOWS. VERY SOLID BODY THE CAR IS PAINTED PPG # 61303 STREET ROD COLORS "SHERBET PEARL" (NOTE: THE PICTURES WERE TAKEN IN THE SUN SO COLOR MAY LOOK A LITTLE PINKISH IN SOME PICS)TRUE COLOR IS MORE OF A CORAL OR APRICOT. THE HOOD WAS SHAVED AN FILLED THE DECK LID WAS SHORTENED AND THE REAR BODY PANEL LENGTHENDED "NEW " PONTIAC LED TAILAMPS "NEW" HALOGEN BRITE LIGHT HEADLAMPS V BUTT WINSHIELD WITH NEW SEAL, ALL OTHER GLASS IS NEW GRAY TINTED OPERATING COWL VENT "NEW" NOS OUTSIDE DOOR HANDLES INSIDE HOOD AND TRUNK RELEASES "NEW" DOOR PANELS, CUSTOM WINDOW AND DOOR HANDLES TILT STEERING COLUMN NEW WIRING HARNESS, ALL ELECTRONICS OPERATE. POWER STEERING RECESSED STAINLESS STEEL FIREWALL
[Re: 05dakota]
#476608
09/22/09 05:11 PM
09/22/09 05:11 PM
Posts: 1,392 Thayer, MO
bohmer2
Thayer, MO
probally needs new leaf springs?
I think it has more to do with how the front sits and not the rear but it may just be new leafs. I have looked at the photos and I cant figure out the front suspension/steering. It really looks odd as it appears to be a mix of stock parts with a rack and pinion. Based on what I see in the photos regardless of the color I would have to look that car over in detail in person and take it for a ride before I would consider purchasing.
[Re: bohmer2]
#476609
09/22/09 10:48 PM
09/22/09 10:48 PM
Posts: 10,528 Freeport IL USA
poorboy
Freeport IL USA
Looks to me like it has the stock suspension, least the front is, still has the drum front brakes too. I'm betting they used the stock rear springs also.
The front suspension will work good with a few modifications and several places have a disc brake conversion available. You would probably need to update the master cylinder as well. It says it has a tilt column, but doesn't say if the stock steering box is still in place. 4 years ago, the disc brake conversion, including all new componets, a new master and booster (the small 7" or 8" boosters are a waste of money imho), and a home made rack & pinoin steering with a rebuilt rack set me back over $1,000. With even the small hemi, the stock brakes are going to be scary, at best. I also suspect the rear springs are likely shot, originally they were wrapped in tin so they could be greased, after the grease went away, the tin wrap held water and tended to rust the leafs until they broke, gives that taildragger look this car has.
To rebuild the Hemi, even the small one, costs a few grand and then there is the other stuff that was done. I'd still want to look the body over for rust, the stock suspension and brakes detracts from the value, and I'd have to change the color. Given the current ecominic conditions, I would be hard pressed to go much over $4,000-$5,000, and the body and paper work better be good. Your likely going to dump another $2,000 or close, to make it a great driver, if you can deal with the color. Paint and body work is expensive if you can't do it yourself. Gene
I just read there is power steering on the car, originally there was no such thing, so I have to wonder what steering box they are using.
[Re: poorboy]
#476611
09/23/09 09:25 AM
09/23/09 09:25 AM
bohmer2
Thayer, MO
In the Q&A on the ebay ad he says it has the stock from suspension with a power rack. He doesnt say but it looks like a mustang rack.
[Re: 05dakota]
#476613
09/30/09 01:38 AM
09/30/09 01:38 AM
Posts: 1,757 levittown pa
fstfish66
levittown pa
the rack is probably a fat man kit, posie has rear leafs to lower that rear end,,,
1966 barracuda prostreeter super charged 340(SOLD) 1940 dodge coupe 241 hemi street rod 2014 ram express hemi 4x4 dailey driver 2015 cherokee 2013 R/T classic
