Re: Super duper gas miledge 273/318 experiment !!! UPD
[Re: TC@HP2]
#47687
02/15/08 04:34 PM
02/15/08 04:34 PM
Posts: 1,061 New Mexico
dmerc
New Mexico
Here is something interesting. A stock 340 4 speed cam (268/276) had 44 degrees of overlap. My roller cam has 41 degrees of overlap instead of 8. I used the wrong duration numbers to figure it. So this explains why I get 155 psi cranking compression with a 10.2 to 1 calculated compression ratio. Dave is right I'll be giving up some gas mileage, but hopefully not too much.I'll just have to drive faster to get the engine in it's efficiency range. Then the air drag will kill me Still it should give at least 20 MPG
[Re: 360view]
#47689
03/01/08 02:56 PM
03/01/08 02:56 PM
Posts: 910 Southern Oregon
toyotajeep
Southern Oregon
It has been a few weeks, has their been anymore data collected?
I am very interested in this since I currently am building a car and deciding which path to take.
Thanks, ROB
1989 Dodge Cummins & 1989 Dodge W-250
[Re: GO_Fish]
#47691
03/01/08 04:41 PM
03/01/08 04:41 PM
Posts: 27,453 So Cal
autoxcuda
So Cal
Per the Moparts archives, 67-71 A engined A bodies weigh 3000- 3200 lbs. Do you feel that weight saves that much more gas than aerodynamics?
Those numbers are out of the MP books. They are all light on reality.
My 68 Cuda coupe 340 auto 11.75 disk conversion aluminum intake non A/C car steel rims 1/2 tank gas lighter weight modern bucket seats aluminum master after market steering wheel (pick up a rallye steering wheel sometime!)
All that was 3340 on a cert. grain elevator scale.
[Re: autoxcuda]
#47692
03/01/08 06:54 PM
03/01/08 06:54 PM
toyotajeep
Southern Oregon
I had a bonestock, 100% stock, 1973 318 Duster that got around 16, and that was mainly hwy. Almost all hwy in fact. It was a bit disheartening.
I have really enjoyed the build and am contemplating something similar with one of my early A's.
Thanks for the update.
ROB
[Re: toyotajeep]
#47694
03/02/08 01:49 PM
03/02/08 01:49 PM
toyotajeep
Southern Oregon
I would think that my single exhaust etc. weren't helping my situation. It was a one owner, and the guy told me that it got maybe 18 at best when new. I was not real excited when I saw that 16 MPG. I was thinking that some headers and a mild cam etc. I could do that good. It ran so well that I didn't have the heart to screw it up so I sold it. Should have kept it. ROB
[Re: toyotajeep]
#47695
03/13/08 12:52 AM
03/13/08 12:52 AM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
I just wanted to throw out an update on a couple things. 1. It has been warming up around here a little and it started pinging a little on heavy accel so I topped off the tank with about 5 gals of 93 and that made it quit. It had a mix of 89 and 87 in it. I think I will be useing 93 from here on out. 2. I have only driven strictly in town with this last half tank and it got 19 again. I finally hooked up a vacume gauge to watch when driving and it's kinda interesting. I can keep the vaccume at 20 inches cruising at 70 on a flat road with no wind. It only pulls 25 idleing in park. I though it would be a little higher idleing and lower cruising. This still leads me to beleive it would love an OD gear. I bet in town it could go over 20 and I could easily knock down 30+ on the highway especially if it was a 5-spd manual OD
[Re: patrick]
#47698
03/13/08 10:25 AM
03/13/08 10:25 AM
HotRodDave
Kalispell Mt.
I thought about water injection but figured it would be a pain to keep up with and install compared to the mabey 1 mpg it would give me if that. It is cheaper to operate now than before. Conservitivly, under the same driving conditions I am getting 5 or more mpg better in town or highway so... 27 / 3.45 = about 12.7777 cents per mile VS 22 / 3.25 = about 14.7727 cents per mile On a 15 gallon fill-up I save about $9.58 over what it would have been before. Plus it makes a nice chunk of extra hp over the old motor so I don't mind the premium On top of that I save a couple bucks on soda and candy bars because I fill up less often
[Re: HotRodDave]
#47704
03/19/08 09:49 PM
03/19/08 09:49 PM
Posts: 8,089 Sorrento, BC, Canada
4speeds4me
OK...I am losing sleep at night, and this is part of the reason. I have a 64 Valiant Signet. I am debating a mimic of sorts on Dave's idea here. I have 2 318's to choose from...one Mag and one 302 headed roller from the late 80's. Dave utilised the 273 solid cam. Will it hurt this project to run a roller? And if not, what kind of specs (duration, LSA, lift) should I be looking for? Target CR with quench? Will the benefit of a few less pounds also help? I can go wherever I want with this in some ways...and am seriously thinking that I will go 4-speed. 833 with 2.7-2.9's, or 833OD with 3.2-3.5's? Or chuck it all and do the same thing with a \6? I keep thinking that the theory of light recip assembly gets blown out the window with the 225, as that crank with it's 4.25" stroke ain't light, and it gets tougher to get a cam with specific specs, and exhaust becomes more costly to make it work efficiently (1 of Dutra's manifolds is the same price as Harold's Spitfires...) as well as carb/induction limitations. Just thinking out loud and looking for a bit of feedback before I start into it...
Thanks.
2 Demons...no, not my kids!
