Heater box removal? #473319
09/20/09 12:19 PM
09/20/09 12:19 PM
Midwest
Sidewinder Offline OP
Midwest
Is there an easy way to remove a heater box from a 72' Charger?Were is the best place to start unbolting it?Is there any tricks to it?
Thanks!
Re: Heater box removal? [Re: Sidewinder] #473320
09/20/09 12:28 PM
09/20/09 12:28 PM
SW Fla.
CYACOP Online content
CYACOP  Online Content
SW Fla.
disconnect heater hoses
remove radio (makes it easier)
remove ductwork inside off of heater box
pull seats back or out
remove blower motor from under hood
remove nuts on firewall
remove bracket/nut up by glovebox (may need to remove glove box)
drop it down and out
That will get you started
Re: Heater box removal? [Re: CYACOP] #473321
09/22/09 10:37 PM
09/22/09 10:37 PM
Midwest
Midwest
The interior of the car I'm taking it out of is all out of it.I'm pretty much to were you ended up in your post.Will it come out now without breaking anything on the heater box?Thanks for your help.
Re: Heater box removal? [Re: Sidewinder] #473322
09/23/09 10:04 AM
09/23/09 10:04 AM
SW Fla.
SW Fla.
Should slide out but might be a little tight between dash and floor. Just be careful as to not break the studs sticking out of the back of the box. Reinstall in reverse order. I have done it by myself by pushing it up on the inside and catching the bracket by the glovebox to hold it in place until you can climb out and catch the firewall nuts. With the right cuss words it shouldnt be too difficult.
Re: Heater box removal? [Re: CYACOP] #473323
09/23/09 02:40 PM
09/23/09 02:40 PM
scratchnfotraction Offline
on my 85 truck I had to unbolt the one bolt that holds the dash to the side
then the dash pulled out just enuff to let the box out
may take a look and see if that might work for you also
Re: Heater box removal? [Re: CYACOP] #473324
09/25/09 11:11 PM
09/25/09 11:11 PM
Midwest
Midwest
I know some of those words to that work in a pinch. I'm ready to attack it now.Thanks Again.
Scratchnfotraction
I'll keep what you said in mind.
Thanks!
