69 Super Bee Rallye Instrument Panel Removal #473022
09/20/09 01:37 AM
09/20/09 01:37 AM
Modesto CA
BFASTER Offline OP
BFASTER  Offline OP
Modesto CA
I want to remove the gauges and 'restore' the plastic lens and put brighter bulbs in. I have all the screws out, now what? (speedo cable is obvious)
Are there any tricks or tips on removal?
1969 Dodge Super Bee Hardtop 2007 Nissan Altima 3.5SE
Re: 69 Super Bee Rallye Instrument Panel Removal [Re: BFASTER] #473023
09/20/09 02:05 AM
09/20/09 02:05 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
So Jim, is the Bee roadworthy yet? We're taking a drive next Saturday...
Re: 69 Super Bee Rallye Instrument Panel Removal [Re: BFASTER] #473024
09/20/09 06:56 AM
09/20/09 06:56 AM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
you can reach around and un clip the speedo with a small hand...limber back and a bit of patience...You also will need to remove the radio bezel and lower the steering column to get clearance when removing...be careful of lower right corner..easy to break corner of face bezel..you also have to get it out far enough to remove the pos and neg from ammeter..then all the other plugs...the wiper switch and squirt are best to label before pulling...others are sort of obvious..hope this helps
Re: 69 Super Bee Rallye Instrument Panel Removal [Re: 1_WILD_RT] #473025
09/20/09 12:59 PM
09/20/09 12:59 PM
Modesto CA
BFASTER Offline OP
BFASTER  Offline OP
Modesto CA
Yes it is. Still in primer and I need to install new hood scoop. Also I'm getting a few leaks fixed this week, hopefully!
Where ya goin?
Re: 69 Super Bee Rallye Instrument Panel Removal [Re: terzmo] #473026
09/20/09 01:01 PM
09/20/09 01:01 PM
Modesto CA
BFASTER Offline OP
BFASTER  Offline OP
Modesto CA
Thank you for the tips. Corner is already broken so I don't have to worry about it.
Re: 69 Super Bee Rallye Instrument Panel Removal [Re: BFASTER] #473027
09/20/09 01:06 PM
09/20/09 01:06 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
You have a PM
