Re: Whats wrong no oil pressure when pre-oiling 400?
[Re: DaytonaTurbo]
#473006
09/20/09 01:45 AM
09/20/09 01:45 AM
Posts: 153 Georgia
wh23g3g
Georgia
I guess I'll have to go get a 1/2 drill or borrow one. I know I shouldve gotten a stock oil pump or a high volume but it's what we had in stock. I'm building this 400-4bbl stock. It's already been bored .040 over, there wasn't a ridge just needed a honing, 3-angle valve job on stock heads, Speed Pro/Sealed Power Cam, Sealed Power bearings, Hastings Cast rings, Elgin springs, MP windage tray, 73 HP exhaust manifolds, 73 iron 4bbl intake, remanufactured Carter Thermoquad, and 73 4bbl air cleaner. So it's about as stock as you can get. Hopefully it will just be a good cruising car. I've got a stock rebuilt 1975 727, 8.75 with 3.91 posi, front/rear sway bars, Accurate dual exhaust, and the coolest thing a Standard gauge cluster from a 72 Highway Patrol Coronet reading "Certified Speedometer". I did want to add a tee and plug in a mechanical oil pressure gauge as well as my original oil light. I has a bad experience with my oil pump giving up on a winter road trip in Kentucky in my daily driver Ranger but it did have 228,000 miles but no warning and no changing that oil pump on the side of the road. Any articles on how to do a dual oil pressure gauge/light hookup anywhere?
[Re: marks69]
#473010
09/20/09 12:06 PM
09/20/09 12:06 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
big block is counter clockwise..
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: marks69]
#473011
09/20/09 12:07 PM
09/20/09 12:07 PM
Posts: 8,716 Baltimore/Denver
64Post
Baltimore/Denver
Somebody above was correct. You need to spin the drill the other way.
Yeah, but he said he was spinning it CCW...
[Re: marks69]
#473012
09/20/09 12:19 PM
09/20/09 12:19 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Counter clockwise is right for a BB (as he stated in the first post). Clockwise small block. Take the pump off & fill with oil. Air locks are not uncommon.
[Re: wh23g3g]
#473016
09/20/09 05:35 PM
09/20/09 05:35 PM
Posts: 15,548 Norwich CT USA
moparts
Norwich CT USA
Paper gaskets work best with alum, intakes.
Cast intake no need.
But the paper ones you do want are the real thin ones so that everything still lines up.
Tom ,
2011 Ram 3500 C&C Diesel 2009 Challenger R/T 1971 Challenger Conv. 511/4 speed 1970 Challenger R/T 503/727
