How do you check a OEM tach outside of the car? #472822
09/19/09 05:47 PM
09/19/09 05:47 PM
PA
P
plumcrazycuda Offline OP
P
PA
I am putting a rally dash in my car and would like to check the tach befor putting it in and finding out I need to that it back out to get it working. Is there a way to check it? It is a 72 to 74 e body rally dash.
Re: How do you check a OEM tach outside of the car? [Re: plumcrazycuda] #472823
09/19/09 09:03 PM
09/19/09 09:03 PM
Roswell, GA - near Atlanta
cloneguy Offline
super street
cloneguy  Offline
super street
It's easy.
Run a wire from the neg on the coil to the spade lug on the back of the tach.
Run another wire from 12v positive to the long threaded screw on the back of the tach.
Touch the tach itself to ground and have someone start the car.
Done.
Martin, GA Quality Auto Restoration with Fair FIXED Pricing. Fast-N-Dangerous@comcast.net
Re: How do you check a OEM tach outside of the car? [Re: cloneguy] #472824
09/20/09 09:43 PM
09/20/09 09:43 PM
PA
P
P
PA
Thanks cloneguy,I will try it tomorrow.
Re: How do you check a OEM tach outside of the car? [Re: plumcrazycuda] #472825
09/20/09 10:55 PM
09/20/09 10:55 PM
Texas
6packattk Offline
6packattk  Offline
Texas
Nice cuda collection,I am jealous...
Re: How do you check a OEM tach outside of the car? [Re: 6packattk] #472826
09/21/09 12:12 AM
09/21/09 12:12 AM
PA
P
P
PA
Thanks,I think
Re: How do you check a OEM tach outside of the car? [Re: plumcrazycuda] #472827
09/21/09 10:06 AM
09/21/09 10:06 AM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
You can also use a tach calibrator like the one RT Engineering sells. Attach the DC connections to a 12V supply and the calibrator to the input.
I had an old one I cobbled from a filament transformer and a capacitor to simulate the engine but due to CRS I cannot remember where it is to tell you how to make it.
Is that a B3 cuda with black vinyl? Mine is B3 with white top and stripe.
Craig
