Ladder bars in street driving? #472118
09/18/09 09:52 PM
09/18/09 09:52 PM
West Plains, MO
DrCharles Offline OP
West Plains, MO
Just wondering if anyone drives a ladder-bar car on the street, and how much it really does affect the cornering.
Obviously if there is a spool there will be problems (and that has been beat to death here before) but I am thinking a limited slip diff.
thanks
Charles
Re: Ladder bars in street driving? [Re: DrCharles] #472119
09/18/09 10:31 PM
09/18/09 10:31 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
Ladder bars are fine for going forward. Not the best idea if you want to go roundy round. just asking but why would you want ladder bars? Nothing works better then a good adjusted pinion snubber.
Re: Ladder bars in street driving? [Re: Dougsmopars] #472120
09/18/09 10:39 PM
09/18/09 10:39 PM
Lebanon, TN
bronzegtx Offline
bronzegtx  Offline
Lebanon, TN
Have to disagree. Pinion snubber works good till you get enough power, then ladder bars work great.
Re: Ladder bars in street driving? [Re: Dougsmopars] #472121
09/18/09 10:39 PM
09/18/09 10:39 PM
West Plains, MO
West Plains, MO
I know they're not the best, what I want is actual stories about turning corners at stoplights, driveways etc.
Pinion snubbers do work but they beat the living snot out of the floorpan too... and would not be very driveable on the street either? how can the rear end move up and down with bumps if the upward travel is limited to 1/2"?
Re: Ladder bars in street driving? [Re: DrCharles] #472122
09/19/09 08:04 AM
09/19/09 08:04 AM
Baton Rouge, La.
StandOnIt Offline
StandOnIt  Offline
Baton Rouge, La.
We've run ladderbars on the street for years. I think the cornering issues are due to no sway bars and the skinnies up front. There is a pretty good lean to the cars when you corner and the ladder bars rattle a bunch (upper coilover mounts mostly). Usually have ground clearance issues with the front crossmember mounts. The last one, we had to cut the lower part of the mounting holes off when we got it adjusted so it wouldnt drag when we crossed a speedbump or pulled in a driveway or something. All in all, I love ladderbars, they just look good. I had a friend that put the clamp on ones with the stock leafspring setup on a Torino one time, Didnt work very well but it looked cool...
76' Volare, 5.9 magnum w/Iron heads. New best 10.68 at 123 mph 1/4 mile.
Re: Ladder bars in street driving? [Re: DrCharles] #472123
09/19/09 09:45 AM
09/19/09 09:45 AM
MNobody Offline
MNobody  Offline
I have ladder bars and a 3:91 suregrip, i see no issues with cornering or turning corners but i don't race around corners either.
