Re: My 440 is a slug, please help.
[Re: Joshs68]
#471599
09/20/09 06:11 PM
09/20/09 06:11 PM
Initial timing is very important! ask a carb shop if you want a second opinion. What is the total timing? I would give it more initial. try for 15-18* initial with a total of 35-37* should be plenty.
EXACTLY.......Don't ever listen to ANYONE that tells you otherwise.........Just as you discovered, initial timing is EXTREMELY important.........You might read this THREAD to better understand ........
