DUAL POINT DISTRIBUTOR #471084
09/17/09 06:18 PM
09/17/09 06:18 PM
Anonymous OP
Anonymous OP
I have a 70 challenger number matching 340 6 pack car with a dual point distributor. My problem is the diaphragm in the cannister is ruptured. Does anyone know where a new, nos or used cannister with a good diaphragm can be found. All help would be appreciated. THANKS, ROGER
Re: DUAL POINT DISTRIBUTOR #471085
09/17/09 07:57 PM
09/17/09 07:57 PM
Rancho Cucamonga, CA
D_C Offline
D_C  Offline
Junkyards, Mopar Swap meets, EBay, Mopar Performance Outlets and Car Dealers, some regular or specialty autoparts stores.
You can test a "used" one with a hand-operated vacuum-pump available at autoparts stores.
I believe it is considered a "normal wear" type part, so replacements should be (somewhat) commonly available.
I searched Summitracing, "Mopar Vacuum Advance Canister" and this came up:
Mallory (Mopar?) Vacuum Canister
Re: DUAL POINT DISTRIBUTOR [Re: D_C] #471086
09/17/09 08:40 PM
09/17/09 08:40 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
ebay also should be reasonably easy to find one dan
Re: DUAL POINT DISTRIBUTOR #471087
09/17/09 10:08 PM
09/17/09 10:08 PM
locate/pm "joesixpack" here on the board.
Re: DUAL POINT DISTRIBUTOR #471088
09/17/09 11:50 PM
09/17/09 11:50 PM
South, FL
cudaized Offline
cudaized  Offline
South, FL
I had mine rebuilt. It works like new.
It is not an easy piece to find NOS, or even used.
If you need the info, I can find the company's name.
Ola
cudaized@cudaized.com
1970 `cuda340 convertible 4-speed Rallye Red with Red interior
cudaized.com
1970-71 Plymouth and Dodge E-Body Convertible Registry
ebodyconvertibleregistry.com
Re: DUAL POINT DISTRIBUTOR [Re: cudaized] #471089
09/20/09 09:47 PM
09/20/09 09:47 PM
Anonymous OP
Anonymous OP
I would appreciate that info. thanks ROGER.
r35ford@msn.com
