Re: Wheel bearing adjustment technique
[Re: SPWC]
#470108
09/16/09 03:26 PM
09/16/09 03:26 PM
RapidRobert
Wheel off the ground tighten it until there is just zero play then go a skosh more then clock the tin piece so the cotter key will go thru. The factory procedure is if you are adding grease to (I believe) a new bearing so in your case if you are greasing the bearings just tighten them up snug as you rotate the wheel then loosen & retighten to zero & a skosh more.
[Re: SPWC]
#470110
09/16/09 06:00 PM
09/16/09 06:00 PM
Posts: 25,743 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The later FSM's say to tighten the nut finger tight.
