E85 & chamber carbon deposits? #469848
09/16/09 09:37 AM
09/16/09 09:37 AM
USA
3
360view Offline OP
Moparts resident spammer
360view  Offline OP
3
USA
For those running E85 fuel,
do you see more, less, or the same amount of
carbon deposits
inside the combustion chamber,
on the piston crown
or on the spark plugs?
Re: E85 & chamber carbon deposits? [Re: 360view] #469849
09/17/09 09:09 AM
09/17/09 09:09 AM
USA
3
360view Offline OP
360view  Offline OP
3
USA
btt
Re: E85 & chamber carbon deposits? [Re: 360view] #469850
09/17/09 12:21 PM
09/17/09 12:21 PM
pgh pa
captaindodge Offline
pgh pa
Since I added 30% E-85 to my '69 440 10:1 engine
I'm able to add 5 degrees more timing with no ping. I also used E-85 in my '81 Kawasaki 440 8:1
motor and it stopped the pinging that it has had since day 1, even though I use 93 octane. No timing change. Finally I used it in my 25 year old
Briggs & Stratton with no ill effects.
Can't say about the carbon deposits but I would ask the guys in Race Only. E-85
Re: E85 & chamber carbon deposits? [Re: captaindodge] #469851
09/17/09 10:54 PM
09/17/09 10:54 PM
Missouri
convertriple Offline
super gas
super gas
Missouri
Did you have to change much to run the E85 blended with your unleaded?
Re: E85 & chamber carbon deposits? [Re: convertriple] #469852
09/18/09 08:02 AM
09/18/09 08:02 AM
pgh pa
pgh pa
I did not change anything. E-85 is 105 octane.
Re: E85 & chamber carbon deposits? [Re: captaindodge] #469853
09/18/09 06:31 PM
09/18/09 06:31 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
It tends to clean out carbon and leaves very little of its own. After running e-85 in my cuda with no changes at all it cleaned the soot out of the exhaust pipes.
