newbie for cam install #468784
09/15/09 10:01 AM
09/15/09 10:01 AM
montreal, quebec, canada
jimmy71demon Offline OP
ok so my cam bushings r in, and im ready to install my cam. what do i need to know (do's and dont's) about doing this? also there is a bit of a residue like substance on the cam in some places. i was told to leave it there instead of rubbing it off with my fingers. should i jus apply the lube on top of this , or should i use some sort of cleaning agent?
thaks in advance
jimmy
Im goin fast Mom!
Re: newbie for cam install [Re: jimmy71demon] #468785
09/15/09 10:05 AM
09/15/09 10:05 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
what motor in car out motor assemble what cam??
I would clean it and apply lube to bearings in block and on cam once in block coat lobes liberally with lube before lifters go in!
Re: newbie for cam install [Re: Dodgem] #468786
09/15/09 10:37 AM
09/15/09 10:37 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
Before installing the cam coat the lobes liberally with cam lube.
Re: newbie for cam install [Re: MoparforLife] #468787
09/15/09 11:19 AM
09/15/09 11:19 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
DONT pour oil over the cam after you lube it
Re: newbie for cam install [Re: GTX MATT] #468788
09/15/09 12:13 PM
09/15/09 12:13 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
find a long bolt to use as a handle on the cam
coat the lifter bottom only in lube, the rest in oil.
after the cam, lifters, pushrods, springs, and rockers are in, mark the top of the lifters, turn the engine over a few times by hand, and check to make sure they rotate.
2017 Grand Cherokee Overland
Re: newbie for cam install [Re: Dodgem] #468789
09/15/09 02:58 PM
09/15/09 02:58 PM
its a 340 block stroked to 416. the motor is out of the car and right now assembled up to the cam. the cam is a flat tappet from comp cam.
what should i use to clean the cam? i dont want to use a product that will make the lube not wanna stay on it at all....
Im goin fast Mom!
