Wideband air/fuel gauge question #462701
09/07/09 09:37 PM
09/07/09 09:37 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
I got my FAST a/f gauge installed, did a quickie deal since I plan to move it from car to car....
...seems to work pretty well for a basic gauge/playback device, but I have a quick question:
Will pan evac mess up the accuracy, or damage the o2 sensor?
I have the 02s a couple inches upstream of the pan evac outlets (which seems OK), but I'm pretty sure they do try to backflow under decel....otherwise, they wouldn't need check valves....
Re: Wideband air/fuel gauge question [Re: ZIPPY] #462702
09/07/09 09:43 PM
09/07/09 09:43 PM
Appalachia
RedRam Offline
RedRam  Offline
Appalachia
yes, the pan evac fumes/gasses with throw the 02 readings off.
Leaded race fuel will kill the sensor over time, BTDT.
Re: Wideband air/fuel gauge question [Re: RedRam] #462703
09/08/09 09:43 AM
09/08/09 09:43 AM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Thanks! ...was somewhat concerned with that, don't want to mess anything up. I'll pull the hoses off for now.
