71 383 fuel line configuration #462535
09/07/09 08:30 PM
09/07/09 08:30 PM
La Verne, CA
lakerism Offline OP
lakerism  Offline OP
La Verne, CA
Can someone post an engine pic showing the stock fuel line config from fuel pump to the carb? I think mine is routed too close to the block and distributor and the heat is causing some vapor lock. Thanks!
Re: 71 383 fuel line configuration [Re: lakerism] #462536
09/08/09 12:56 AM
09/08/09 12:56 AM
Midwest
Chargerfan Offline
Chargerfan  Offline
Midwest
I don't have a pic but if I remember correctly the fuel line goes up between the altenator and block, past the dist, over the valve cover to the carb. Are you using the original line or hose?
2011 Challenger R/T
2017 Ram 1500 BIG HORN Edition
Re: 71 383 fuel line configuration [Re: lakerism] #462537
09/08/09 01:15 AM
09/08/09 01:15 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
This is a 70 but assuming it has a Carter carb it's correct...
Re: 71 383 fuel line configuration [Re: Chargerfan] #462538
09/08/09 11:02 AM
09/08/09 11:02 AM
La Verne, CA
lakerism Offline OP
lakerism  Offline OP
La Verne, CA
It's a hose from the filter up behind the alt but over the top of the dist shaft over the valve cover to the Holley, maybe route it under the dist shaft and over the valve cover to the carb?
Re: 71 383 fuel line configuration [Re: lakerism] #462539
09/08/09 02:25 PM
09/08/09 02:25 PM
Midwest
Chargerfan Offline
Chargerfan  Offline
Midwest
I would go back to the original steel line. The steel will be rigid and hold itself away from the block, the hose will just lay against it. Another option might be going with a braided line for more protection.
2011 Challenger R/T
