Dashboard Turn signal Light 1969 Satellite Convertible #462445
09/07/09 07:50 PM
09/07/09 07:50 PM
Anonymous OP
Anonymous OP
I'm having a problem with my right turn signal dash light not working. I replaced the cancel cam assy and both wires going to the cancel cam. All outside signal lights are working, left dash signal works fine. Replaced bulb for right side but can't get it to work, any ideas? Thanks! (it does come on once in a while)
Re: Dashboard Turn signal Light #462446
09/07/09 08:02 PM
09/07/09 08:02 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
what model car?
Re: Dashboard Turn signal Light [Re: Dougsmopars] #462447
09/07/09 08:39 PM
09/07/09 08:39 PM
Andrewh Offline
Andrewh  Offline
Take the gauge cluster out and see if the pin is messed up, the wire is loose in the plug, or if the board is messed up.
I have a right turn signal that doesn't turn on in the dash either.
Turns out part of the board peeled. Delaminated, or whatever they call it and the circuit to that light is bad. Scraped it away and ran a bead of solider to connect the points and it worked for a while.
Just waiting now for the guy making new boards to finish the one for my car so I can replace it instead of the rigged thing that doesn't work anymore.
Re: Dashboard Turn signal Light [Re: Andrewh] #462448
09/07/09 09:13 PM
09/07/09 09:13 PM
Dougsmopars Offline
Dougsmopars  Offline
Check the plug at column for poor conections. Most times you'll find your problem is there. They sell a repair conector.
Re: Dashboard Turn signal Light [Re: Dougsmopars] #462449
09/08/09 09:55 PM
09/08/09 09:55 PM
Anonymous OP
Anonymous OP
Can you tell where i can find the connector and a complete turn signal switch, thanks. darc1@sbcglobal.net
