correct color of carb dash pot bracket????
#46207
10/06/07 12:31 AM
10/06/07 12:31 AM
This item was only on cars that came with factory manual transmissions. I am looking for the correct color of the bracket that mounts dash pot to the carb. This bracket goes around where the fuel line goes into the carb. Anyone that can help me with letting me know what color it was originally, please post. The carb resto shop that redid it the last time painted it a dull silver cad color which I can almost say is wrong.
Any help would be appreciated.
Thanks,
Brian
Re: correct color of carb dash pot bracket????
[Re: ScottSmith_Harms]
#46209
10/06/07 12:54 AM
10/06/07 12:54 AM
Scott, yes that is the correct part. So I guess it would be the same plating as what my spark coil bracket would be then.
[Re: ]
#46210
10/06/07 01:01 AM
10/06/07 01:01 AM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Here's another example, it's gold but looks to have been possibly replaced at one time or another so it's not good solid evidence, I'll know more once I get it appart. What carb # do you have? Quote:
If it was silver, yes, that's the type of plating you'd need. The problem is that most carbs have been rebuilt, and some were incorrectly plated at that time. I photograph each carb I recieve before plating (these two are examples of carbs I restored before I touched them) and try to determine if they are original or not before continuing. It's not always easy determining which color they were originally, sometimes impossible if they've already been restored somewhere else, but typically there are enough clues remaining to get it right.
#46211
10/06/07 01:23 AM
10/06/07 01:23 AM
Carb number is Carter 4615 SA
#46213
10/06/07 04:50 AM
10/06/07 04:50 AM
Posts: 6,224 JERSEY
RJS
JERSEY
I purchaced this soleniod and bracket NOS a few years back on epay
#46218
10/06/07 02:17 PM
10/06/07 02:17 PM
Posts: 1,547 Puyallup, Wa.
Steve340
Puyallup, Wa.
I've seen some rebuilt carbs where the rebuilder just glass beaded the whole thing, linkages and all. It doesn't look right and also, almost imediatly starts rusting all the metal parts due to protective coating on them anymore.
[Re: Steve340]
#46219
10/06/07 02:37 PM
10/06/07 02:37 PM
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
You won't see that with this rebuilder
[Re: ]
#46220
10/06/07 06:40 PM
10/06/07 06:40 PM
Posts: 8,827 Houston, Tx
hemi68charger
Houston, Tx
Does ANYONE have an extra bracket and dashpot? I have the lever that attaches to the throttle shaft. This is for my 440 4-speed '69 C500....
Cheers,, Troy
PS: I've posted this in the wanted section some time ago with no success....
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
#46222
10/06/07 06:45 PM
10/06/07 06:45 PM
hemi68charger
Houston, Tx
I come accross them pretty often 68, I'll find you one.
Thanks Scott...
It's those little detail items I like to have right on my cars...
[Re: Dennis_K]
#46227
07/29/08 10:38 AM
07/29/08 10:38 AM
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
I just dug this post up via the search feature, and like Troy, I posted an ad in the parts wanted section with no results. Scott Smith, were you able to locate one of these brackets when Troy asked about them? Would you happen to have another one or know where I could get one? Anyone else? Thanks
Yes, I have an NOS example and it's out for bid right now to have them reproduced.
