Intake gasket failure? #461782
09/07/09 12:50 PM
09/07/09 12:50 PM
New Jersey, USA
JeffRacerG Offline OP
New Jersey, USA
Had a strange occurance on my 383 where exhaust was suddenly blowing out of the valve cover breather hole. Took it to a mechanic and he told me the intake manifold gasket failed and allowed exhaust to be pushed into lifter galley from the exhaust crossover from heads to intake manifold. Is this a common problem?
Re: Intake gasket failure? [Re: JeffRacerG] #461783
09/07/09 01:21 PM
09/07/09 01:21 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Not common at all. I would make sure it is exhaust, and not excess blowby from hole in piston etc. Compression check may be in order.
Re: Intake gasket failure? [Re: buildanother] #461784
09/07/09 01:28 PM
09/07/09 01:28 PM
New Jersey, USA
New Jersey, USA
Compression was fine. Around 140 for all eight. That was when I took it to a mechanic. He seems to have fixed it.
Re: Intake gasket failure? [Re: JeffRacerG] #461785
09/07/09 01:33 PM
09/07/09 01:33 PM
chicagoland,usa
chicagoland,usa
Excellant.
