Indy heads #461654
09/07/09 10:29 AM
09/07/09 10:29 AM
Indiana
79_W200 Offline OP
79_W200  Offline OP
Indiana
I am considering getting the 440-1c heads, I would like to see some pictures of them installed. Do the iron version have Indy machined in the end of the head like the alum. ones?
1979 W200 470
Re: Indy heads [Re: 79_W200] #461655
09/07/09 10:44 AM
09/07/09 10:44 AM
Deerfield, Ohio
70dusterjohn Offline
Deerfield, Ohio
My brothers did.. But man those heads are heavy. Even over the stock heads.. Ya better lose some weight somewhere else on the car if you going to use them...
Re: Indy heads [Re: 79_W200] #461656
09/07/09 10:45 AM
09/07/09 10:45 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
The Indy heads with the recessed logo can be easily filed with bondo. It lasted on mine for over 5 years and still looked good when I sold tem.
Doug
Re: Indy heads [Re: 70dusterjohn] #461657
09/07/09 11:07 AM
09/07/09 11:07 AM
Kokomo, IN
540dust Offline
540dust  Offline
Kokomo, IN
They are heavy, just installed a set on a friends 470. The iron heads added a total of 73 lbs to the front end of the car.
Re: Indy heads [Re: 540dust] #461658
09/07/09 11:33 AM
09/07/09 11:33 AM
ky
68roadrunner Offline
ky
#1
Re: Indy heads [Re: 68roadrunner] #461659
09/07/09 04:18 PM
09/07/09 04:18 PM
Indiana
79_W200 Offline OP
79_W200  Offline OP
Indiana
thanks for the pics The engine is a 470 but it is in a pulling truck so the weight is not a problem
1979 W200 470
Re: Indy heads [Re: 79_W200] #461660
09/07/09 07:30 PM
09/07/09 07:30 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Rules must dictate a cast head? I would think that a puller type rig would go right into detonation, when wheel speed goes down. Seems like methanol/aluminum heads would be the low budget answer. (Maybe you guys do run methanol with cast heads, what do I know.
