cylinder pressure and gaskets/fasteners??? #461648
09/07/09 10:11 AM
09/07/09 10:11 AM
MO
P
psycho_440 Offline OP
P
MO
all references i have ever read about head bolts, and gaskets use compression ratio as a guideline...but what about actual cylinder pressure??? now running arp bolts, felpro permatorque blue gaskets with 12.5 comp ratio. cranking cylinder pressure is around 220psi.dist is locked @ 37*. just burnt a gasket between #3 an #5. plan to go to a mls gasket with a set of studs, but just thought i would try to get some opinions. and it took alot of runs for the gasket to finally fail. any help would be great thanx!
Re: cylinder pressure and gaskets/fasteners??? [Re: psycho_440] #461649
09/07/09 10:21 AM
09/07/09 10:21 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Which gasket ? a race gasket or the 8519 ? I had an 8519 fail at 12.2, should have used something better . Also alum heads or iron ? If alum I'd be using studs , especially with that compression.
Run a thread chaser in the block holes before installing the studs , hopefully ythe block didn't get damaged , a failure in that small area can burn thru the deck after the gasket fails.
Re: cylinder pressure and gaskets/fasteners??? [Re: JohnRR] #461650
09/07/09 10:27 AM
09/07/09 10:27 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I run 12.5 domes in the 440.It had the 09 felpros with the iron heads.Now it has their Marine gaskets with the aluminum heads and ARP bolts.No problems ever and the first set wan on for 8 years and the new set 2 years and its street driven.Rocky
Chrysler Firepower
Re: cylinder pressure and gaskets/fasteners??? [Re: therocks] #461651
09/07/09 10:32 AM
09/07/09 10:32 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
You obviously aren't making enough HP for the bolts to be a concern.
Re: cylinder pressure and gaskets/fasteners??? [Re: JohnRR] #461652
09/07/09 10:36 AM
09/07/09 10:36 AM
MO
P
P
MO
running the race gasket (.039) with iron heads. and it has taken prob 50 or 60 passes for these to fail. yes hopefully the block is not hurt. but we will check all that out.
Re: cylinder pressure and gaskets/fasteners??? [Re: psycho_440] #461653
09/07/09 11:33 AM
09/07/09 11:33 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I guess 550 isnt enough to worry about.But it runs and drives.Rocky
Chrysler Firepower
