feul line? for 73 340 e body
#461064
09/06/09 09:05 PM
09/06/09 09:05 PM
Posts: 501 Port Mcneill,B.C.Canada
Islandcuda
Hi all, finally getting some motivation to work on the car. I am looking at new fuel lines and assuming if I buy 3/8 feul and vapor line I should also purchase the 3/8 sending unit. This barracuda,s feul lines were pretty rotten and I think they were the factory 5/16 lines but do want to go bigger as there is lots more power in the 340 and maybe one day drop a 440 in it, thanks Tim
67 cuda new best 1.395 60 10.240 at 128.58mph
Re: feul line? for 73 340 e body
[Re: Islandcuda]
#461065
09/06/09 09:25 PM
09/06/09 09:25 PM
Posts: 7,506 Az
Crizila
Az
3/8" fuel line and sender - the way to go!!!!
Fastest 300
[Re: screamindriver]
#461068
09/07/09 10:20 AM
09/07/09 10:20 AM
Challenger 1
Cincinnati, Ohio
Yes, the 3/8 line will fit right on there...Just keep in mind your original set-up has the vent line from the tank to the canister for emmission control...The older style 3/8 tank sending unit will have a return line provision...So if you wanted to run a factory style vapor separator you'd need an aditional 1/4 inch return line for a 70-71 cuda{from the separator to the sending unit} if going the prebent route....If you don't plan on running the fuel/vapor return simply cap the return on the sending unit.....
Good point, I would recomend installing the third vapor return line to the the sending unit. It's the hot tip to prevent vapor lock. IMO
[Re: Challenger 1]
#461069
09/07/09 10:31 AM
09/07/09 10:31 AM
Islandcuda
okay thanks, the engine bay, or entire car will not be stock looking anyway. I had the vent line just hanging off the frame where the cannister used to be.
