70 Style Voltage Regulator on a 69 Charger????? #460581
09/06/09 10:11 AM
09/06/09 10:11 AM
Far Northeast.
mymcodebee Offline OP
Far Northeast.
Last minute Sunday prep for a toys for tots cruise tomorrow.
My brothers Charger has a new electronic conversion harness. He bought the correct electronic voltage regular(small blue style) and it was defective.
We have tried the point style voltage regulator with no luck. Works for a while and then no good.
Here is the question. Can I cut the voltage reg. connection off an old 70 up style harness and make the 70 and up style voltage regulator work on his car. I am guessing I may need a dual field alternator. If so can I run the second field to the ballast resistor and be OK. Has anyone tried this. His harnesses are all new and I do not want to fry them. I know we should wait for Tuesday and get the right parts but we are just trying to find a way to get it to the show. Thank you for any help and or advise.
Reid
Re: 70 Style Voltage Regulator on a 69 Charger????? [Re: mymcodebee] #460582
09/06/09 12:57 PM
09/06/09 12:57 PM
Iron Station, NC
furygt Offline
furygt  Offline
Iron Station, NC
Can I suggest as an alternative long-term solution that you purchase a stock appearance voltage regulator that has solid state internals compatible with an electronic ignition conversion? The only restriction is a maximum of a 65 amp output alternator. I have been using and selling these for several years and they work great. Email me for more information or check out my ebay auction,item # 180401817992. $25 shipped to your door via priority mail. Payment by PayPal, check or postal money order.
For a short-term solution, you might be able to find an electronic/solid state voltage regulator that does not look correct at your local parts store. I think AutoZone has them. Alternatively, yes, you can use the 70 style voltage regulator and in fact, you might be able to purchase a new 70 style plug end from your local parts store.
Bill
Re: 70 Style Voltage Regulator on a 69 Charger????? [Re: furygt] #460583
09/08/09 01:20 PM
09/08/09 01:20 PM
Far Northeast.
Far Northeast.
Thank you Bill.
I have passed your info on to my brother.
We did have to make due with a 70 style and it worked very well.
Not very correct but got the car there and back.
Thank you for the input.
Reid
Re: 70 Style Voltage Regulator on a 69 Charger????? [Re: mymcodebee] #460584
09/08/09 01:28 PM
09/08/09 01:28 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Thank you Bill.
Thank for the input.
Reid
I'd rather it work than be correct.
Coming soon!!!!
Re: 70 Style Voltage Regulator on a 69 Charger????? [Re: Mr.Yuck] #460585
09/08/09 09:17 PM
09/08/09 09:17 PM
Far Northeast.
Far Northeast.
5 alternators later, we agree too.
