cigarette lighter is not working, help #459974
09/05/09 12:25 PM
09/05/09 12:25 PM
ME
79machocharger Offline OP
ME
I just tryed pluging my cell phone charger into my cigarette light lighter and its not working in my 69 dodge charger. I've checked it with a test light and there's power in the center. Why would it not work when I plug the cord into it, any one have any ideas.
Re: cigarette lighter is not working, help [Re: 79machocharger] #459975
09/05/09 12:32 PM
09/05/09 12:32 PM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
Make sure it's screwed in tight so it has a good ground. Some times when you push your plug in it loses the ground. Never have much luck plugging accessories in old lighter sockets. The one in my van is pretty much useless for accessories.
Re: cigarette lighter is not working, help [Re: NicksGarage] #459976
09/05/09 01:00 PM
09/05/09 01:00 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
quite often I have to sping the plug on housing and get power
Re: cigarette lighter is not working, help [Re: NachoRT74] #459977
09/05/09 06:47 PM
09/05/09 06:47 PM
Port Huron, Michigan
MI_Custumz Offline
MI_Custumz  Offline
I believe the old cigarette lighters are larger diameter. The cell phone chargers fit great in the new size, but sloppy and not getting a good connection in the old ones.
Re: cigarette lighter is not working, help [Re: MI_Custumz] #459978
09/05/09 10:28 PM
09/05/09 10:28 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
if it has power and ground, it's the socket..but make sure u have power when it's plugged in...sometimes the draw will not pull enough voltage through the fuse block then check for a bad connection at the fuse area
Re: cigarette lighter is not working, help [Re: AARCONV] #459979
09/08/09 11:18 AM
09/08/09 11:18 AM
Hunt Valley, Maryland
1fastrunner Offline
1fastrunner  Offline
I had the same problem trying to use my Garmin.
When I wiggled the plug, I could get it to connect, but it wouldn't stay. Is there a chance I could find a newer socket that would work better?
Re: cigarette lighter is not working, help [Re: MI_Custumz] #459980
09/08/09 11:24 AM
09/08/09 11:24 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Yeah mine doesnt fit tight and wants to wiggle around. When I hit a good sized bump it looses its connection and regains it, so the phone is constantly beeping. It gets the job done though.
Re: cigarette lighter is not working, help [Re: GTX MATT] #459981
09/08/09 05:50 PM
09/08/09 05:50 PM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
You'd think by now that they'd come up with a better standard for 12 accessory plugs in cars. I need to add a few extra 12 outlets in my motorhome as one in the dash won't keep a good connection and it's right above my right knee when driving so stuff hanging down is a problem. Last time I went on a trip I brought my jumpstart battery which has a 12v outlet and just used that for the GPS.
Over the weekend, I got a couple 12v outlets out of a Caravan in the junkyard, hopefully they'll be better than the old style with the screw on back.
Re: cigarette lighter is not working, help [Re: NicksGarage] #459982
09/08/09 07:25 PM
09/08/09 07:25 PM
ME
ME
I took it all apart and sandblasted the metal contact piece in the bottom and it works great now .
