72 challenger 340 no spark issue! #459938
09/05/09 11:43 AM
09/05/09 11:43 AM
Menomonie,wi
menomoniemopars Offline OP
Menomonie,wi
Hi Guys.. My Brother has a 72 Challenger with a 69 340 with electronic ignition, I am having problems with a no spark issue.. when i first turn the key on it sparks once, but then u roll it and there is nothing! turn the key back and it sparks once again. I pulled the dist out of the block and with the key on and dist plugged in to harness i spun the rotor by hand and I had the strongest bluest spark at end of coil wire. Put it back in Block back to the samething one spark then none!. I have been fighting issues upon issues with this car and just when i think i am getting somewhere something else comes up!.I have replaced the ballast, A new dist , new ign box . Can someone please help? or is anyone close to menomonie wi?
thanks!!
Re: 72 challenger 340 no spark issue! [Re: menomoniemopars] #459939
09/05/09 11:53 AM
09/05/09 11:53 AM
PA
maxwedge1 Online content
maxwedge1  Online Content
PA
usually when you get the nothing cranking and tries to fire just as you turn key off the pickup coil in the distributor is faulty.
or your power from the ign switch to ballast is bad in the run or crank position.
Re: 72 challenger 340 no spark issue! [Re: maxwedge1] #459940
09/05/09 11:59 AM
09/05/09 11:59 AM
Menomonie,wi
Menomonie,wi
well the dist is new? and we also tried the one that came out of it.. same problem..Also one other thing is I checked for voltage at the hotside of ballast its there and when we go to crank it the other side of the ballast has voltage,but now the other side doesn't is that normal? or is it suppose to maintain its voltage too? so where do i start chasing the wiring at then?...tx!
Re: 72 challenger 340 no spark issue! [Re: menomoniemopars] #459941
09/05/09 03:05 PM
09/05/09 03:05 PM
Massachusetts
N
NortheastMopar Offline
N
Massachusetts
Try replacing te ballast resistor on the firewall.
Re: 72 challenger 340 no spark issue! [Re: NortheastMopar] #459942
09/05/09 07:16 PM
09/05/09 07:16 PM
turn the ign sw to "on" & jump the starter either at the starter relay (large batt terminal to brown (solenoid) wire)or down at the starter itself & see if it will start & if so shut it off then see if the ballast has fire when you crank it with the ign switch & if not trace back to the firewall bulkhead connector(both sides) and further upstream to the ign switch until you find the open. EDIT I (re)read your 2nd post & tell me again which sides of the ballast has/has no fire when "on" and in "crank"
Re: 72 challenger 340 no spark issue! [Re: RapidRobert] #459943
09/05/09 09:59 PM
09/05/09 09:59 PM
Menomonie,wi
Menomonie,wi
I have included a pic of a ballast and which side is which on the car.. and when i go into crank mode the hot side loses juice is this correct? Hot side has the blue wire if that helps or is that my problem cause i am loosing current there when cranking?? I also switched them from top to bottom to see if anything changes and it didn't so i put it back
Re: 72 challenger 340 no spark issue! [Re: menomoniemopars] #459944
09/05/09 11:38 PM
09/05/09 11:38 PM
Are you running a 5 pin ECU?. If you have a VOM pull off both plastic connectors & ohm out both sides. upper left to lower left should be ~ 5 ohms and upper right to lower right should be ~.5 ohms. lower right and lower left should have something when cranking.
Re: 72 challenger 340 no spark issue! [Re: menomoniemopars] #459945
09/06/09 07:45 AM
09/06/09 07:45 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
Tempararily bypass it. Just link the pins together.
Re: 72 challenger 340 no spark issue! [Re: RapidRobert] #459946
09/06/09 10:45 AM
09/06/09 10:45 AM
Menomonie,wi
Menomonie,wi
I believe its a 4 pin module with a 5 pin harness? so your saying top plug is hot and the bottom is my cranking? I am almost positive the car is the other way around as i showed in the pic. also is that .5 ohms? and 5 ohms on the other?
Re: 72 challenger 340 no spark issue! [Re: menomoniemopars] #459947
09/06/09 04:29 PM
09/06/09 04:29 PM
the listed nominal spec on a 4 terminal ballast is 5 ohms on one side and .5 ohms on the other side. It's confusing because you think the .5 ohms (less resistance = more flow) would be the start side and 5 ohms would be the run side(for the coil) but the .5 ohm side is the "run" side(to the coil)which is a correct amount of resistance & as you know the ballast is bypassed completely to the coil for "start". This leaves the 5 ohm side of the ballast which is used for the extra "start" side circuit for the ECU (5 pin only) not the coil. Both the 4 and 5 pin ECU's get running voltage from the blue (ign 1 run) circuit. The 5 pin ECU has 2 circuits, the 5 ohm for starting and the above (ign 1) for running voltage. A spare I have shows 6 ohms from upper left to lower left and 1.4 ohms from upper right to lower right. Lower left has a blue lead switched 12V(ign 1) to it and it jumps across to the lower right with a short blue loop. Upper right is a heavy brown wire which goes to the coil positive pri terminal. The upper left is a green w a red tracer which goes to the ECU connector. The archives state that this green w red tracer wire is not used w a 4 pin ECU AND a 2 terminal ballast but in the factory shop manuals the green w red tracer wire is used with a 5 pin ECU and a 4 terminal ballast. That's what I have so far.
Re: 72 challenger 340 no spark issue! [Re: RapidRobert] #459948
09/06/09 08:29 PM
09/06/09 08:29 PM
Menomonie,wi
Menomonie,wi
Ok thanks!So In my picture I have juice on both bottom terminals when key is on.If I am following u correctly i should only have juice on one side of the bottom of the resistor? I am going back tuesday to my brothers I will check that.. also I talked to him tonight and he said its got a 4 pin harness and a 4 pin module.. it was his 72 charger that has the 5 pin one sorry.. but your description of wire colors sounds right from what i have seen on his. will verify tho tuesday
Re: 72 challenger 340 no spark issue! [Re: menomoniemopars] #459949
09/06/09 11:29 PM
09/06/09 11:29 PM
I reread everything and you have a 4 pin ECU w the (pictured) 4 terminal (dual) ballast, correct? If so (1) see if you have continuity between the upper right and lower right terminals (disconnect both plugs & ohm it if you have a VOM) (2) see that the upper right (brown) terminal has fire when "cranking" & on to the coil positive pri terminal (3) that the "point" of the ECU pentastar connector has fire in "crank".
Re: 72 challenger 340 no spark issue! [Re: RapidRobert] #459950
09/07/09 09:52 AM
09/07/09 09:52 AM
Menomonie,wi
Menomonie,wi
Yes that is correct From what he told me.. also when u say terminals do u mean the plugs on the harness for continuity? or on the ballast? with key on or in start mode? and am I checking for voltage at the pos primary at the sametime in crank mode? Just ground my neg meter wire while checking it? should i disconnect brown wire on relay so i don't turn motor over while checking this?
Re: 72 challenger 340 no spark issue! [Re: menomoniemopars] #459951
09/07/09 10:05 AM
09/07/09 10:05 AM
(1) the terminals(right side top/bottom) on the ballast for continuity (pull both plugs off) (2) then fire at the harness plugs in crank mode (3)ground the neg meter wire (4) yes disconnect the brown wire on the relay. #1 see that the coil and ECU are getting fire when cranking w the ign key
Re: 72 challenger 340 no spark issue! [Re: RapidRobert] #459952
09/07/09 06:57 PM
09/07/09 06:57 PM
Menomonie,wi
Menomonie,wi
ok I am here now and i checked ballast it ohms out. then i checked for fire at hot side and crank side and i have voltage and then i checked for fire at pos side coil in crank and I have fire around 11 volts then i checked at the pentastar and with key on it has around 8 volts go into crank mode and it drops to 3.50 volts or less... so whats going on? where would i be loosing that voltage? where do trace from now? I also looked and it has the 5 pin harness with 4 pin ECU and dual ballast
Re: 72 challenger 340 no spark issue! [Re: menomoniemopars] #459953
09/07/09 07:23 PM
09/07/09 07:23 PM
jump 12V directly from the battery positive over to the "point" of the pentastar & crank it & see if starts then we'll work upstream on that circuit to find the bad connection. EDIT has it ever ran wired up the way it is right now? Just making sure we have it wired correct.
Re: 72 challenger 340 no spark issue! [Re: RapidRobert] #459954
09/07/09 08:37 PM
09/07/09 08:37 PM
Menomonie,wi
Menomonie,wi
I hope your sitting down when u read this ,lol... yes it did run, but we HAVE had other issues with worn timing chain, bad dist, bad dist gear etc and then this now surfaces!,Here is what i found tonight! the pos brown wire was on the wrong side of coil! then i switched that so it was right and checked again same voltage drop!.. then i started to look into the bulk head.And man what I found is just plain unbelievable! someone spliced into the yellow ignition wire on engine side bulkhead and ran that to the ignition on relay and also to the brake light switch below master cylinder! that wire was all melted inside the tape! also the red heavy wire that goes to relay they just ran it thru the damn bulkhead where the connector should have been and spliced into the red on the other side!.So where do i go from here? and do u think this was the problem? How did it even run the other way with the crappy gear ,dist,chain eyt is way beyond me!! I will post a pic later
Re: 72 challenger 340 no spark issue! [Re: menomoniemopars] #459955
09/07/09 09:25 PM
09/07/09 09:25 PM
Yes I am sitting down as that expends the least amt of energy. Well we're making progress. One (system) at a time. www.mymopar.com has factory wiring diagrams, go to mymopar tools/reference in the main menu on the left then click wiring/electrical. It helped me immensely rewiring my 65 Dart. Holler back when you can
Re: 72 challenger 340 no spark issue! [Re: RapidRobert] #459956
09/07/09 09:38 PM
09/07/09 09:38 PM
Menomonie,wi
Menomonie,wi
Here's a pic of the harness and what I marked how it was
Re: 72 challenger 340 no spark issue! [Re: menomoniemopars] #459957
09/07/09 10:00 PM
09/07/09 10:00 PM
I'd cut the splices & go back to basics & run the ign 1(run) out to the ballast upstream side(the blue loop) and to the point of the pentastar and ign 2(crank)out to the yellow solenoid wire.
