Mopar electronic ignition issues........troubleshooting #457993
09/02/09 10:39 PM
09/02/09 10:39 PM
Joplin, MO USA
Robbins Offline OP
Robbins  Offline OP
Joplin, MO USA
I seem to have a problem loosing fire while in start position with the key. If I bump it will hit and run once running it'll never loose it again.
What would cause this?
I seem to have two vehicles with this issue. The other on is a little different as in when I shut the key off it will hit once, but while the key is in the start position I don't have any fire.
Any ideas?
Both stock ignitions.
The coil is hot all the time on both. Both have tach's could this be a problem with the tach.......I wouldn't think so. I did have a tach go bad on my 68 gm car back in the day that wouldn't let the car run........unhooked it and the car ran...........I haven't tried that with either of the trucks that I have.
Thanks.
Moparlee
Re: Mopar electronic ignition issues........troubleshooting [Re: Robbins] #457994
09/02/09 11:02 PM
09/02/09 11:02 PM
I'd take off the brown wire from the starter relay to the starter to(temporarily) disable the starter then check for fire at the yellow "sol" wire to the starter relay and at the "point" of the ECU and at the ballast as you play w the ign sw in "start" & see if you can make it go open. You might pull apart the bulkhead & check it as it's a known trouble spot.
Re: Mopar electronic ignition issues........troubleshoo [Re: Robbins] #457995
09/03/09 01:55 AM
09/03/09 01:55 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
If you are saying it won't fire/start while cranking, but starts once you release the key, then the problem is voltage drop through the battery cables / bad ground connection(s). Or a defective ignition switch.
Consider this scenario: The battery ground wire/connection has 0.1 Ohm of resistance. At 10-amps of current flow, that is a 1 Volt drop, so if you measured from the chassis/engine ground to the battery positive terminal, the voltage would read 1-volt less than the actual battery voltage.
When cranking the starter, you might be pulling 70+ Amps or more, this would reduce the voltage at the ignition module/coil by 7 volts!
This is why when you release the key from the start position, it removes the high current load to the starter, and results in nearly full voltage being avilable at the ignition box/module/ignition coil to fire the ignition.
The fix is to have good battery cables and good clean low resistance connections.
Re: Mopar electronic ignition issues........troubleshoo [Re: 451Mopar] #457996
09/03/09 09:55 AM
09/03/09 09:55 AM
Joplin, MO USA
Robbins Offline OP
Robbins  Offline OP
Joplin, MO USA
Yes, that is the scenario with my 81 short bed.
I'll look into the ground issue and connections.
Thanks guys.
Moparlee
Re: Mopar electronic ignition issues........troubleshooting [Re: Robbins] #457997
09/05/09 11:49 AM
09/05/09 11:49 AM
Menomonie,wi
menomoniemopars Offline
Menomonie,wi
I am having the exact problem be interested to see what u find..
Re: Mopar electronic ignition issues........troubleshooting [Re: menomoniemopars] #457998
09/05/09 12:39 PM
09/05/09 12:39 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Fire on key release is typical ballast resistor. Try replacing these. Check all grounds.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: Mopar electronic ignition issues........troubleshooting [Re: MoparforLife] #457999
09/05/09 12:57 PM
09/05/09 12:57 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
you can check if ballast is defective if when cranking the BRAKE light cluster cames off. If dimms when cranking, ballast works. If brake light cames off, then ballast or a related plug or wire is damaged.
Re: Mopar electronic ignition issues........troubleshooting [Re: NachoRT74] #458000
09/05/09 03:02 PM
09/05/09 03:02 PM
Menomonie,wi
Menomonie,wi
Do U mean goes off? What i did do was pull the dist out of the block and with key on i spun the rotor by hand and I had the most brightest blue spark at end of coil wire!put it back in the block and it only sparks once when key is turned on then once when u turn it off.. We tried two different ballast resistors ETC, has a new dist and a new ign box too, Now if the tach wire isn't hooked up from the coil would this be the problem?
Re: Mopar electronic ignition issues........troubleshooting [Re: menomoniemopars] #458001
09/05/09 03:07 PM
09/05/09 03:07 PM
Joplin, MO USA
Robbins Offline OP
Robbins  Offline OP
Joplin, MO USA
Do U mean goes off? What i did do was pull the dist out of the block and with key on i spun the rotor by hand and I had the most brightest blue spark at end of coil wire!put it back in the block and it only sparks once when key is turned on then once when u turn it off.. We tried two different ballast resistors etc.
Exactly......mine does the same thing.
The ballast thing....I'll try that.
Moparlee
Re: Mopar electronic ignition issues........troubleshooting [Re: Robbins] #458002
09/07/09 02:06 PM
09/07/09 02:06 PM
Joplin, MO USA
Robbins Offline OP
Robbins  Offline OP
Joplin, MO USA
Ok.........When my RC doesn't fire I can unplug distributer & ground the male prong from the harness side and the coil will fire.....plug it back in and the distributor doesn't do any thing.
Makes me think there is something wrong with the distributer, no?
Where is a good brand to buy when it comes to Mopar's stock electronic components?
Thanks for the help.
Moparlee
Re: Mopar electronic ignition issues........troubleshooting [Re: Robbins] #458003
09/07/09 02:33 PM
09/07/09 02:33 PM
Joplin, MO USA
Robbins Offline OP
Robbins  Offline OP
Joplin, MO USA
Anybody ever have good experience with Accel's distributer?
Dizzy
Moparlee
Re: Mopar electronic ignition issues........troubleshooting [Re: Robbins] #458004
09/07/09 04:35 PM
09/07/09 04:35 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I have the accel billetproof distrubitor in the coronet R/T and it has worked great.
http://www.northernautoparts.com/ProductModelDetail.cfm?ProductModelId=1449
$260 for the billet distrubitor, internal electronics, magnetic triggered, adjustable mechanical and vacuum advance, stock style cap.
This is an older model, I think the 53000 series distrubitor is the newer version, but it is more expensive. The main change is the 53000 series has the mechanical advance up top so changing the advance is easier.
Re: Mopar electronic ignition issues........troubleshooting [Re: 451Mopar] #458005
09/07/09 09:50 PM
09/07/09 09:50 PM
Joplin, MO USA
Robbins Offline OP
Robbins  Offline OP
Joplin, MO USA
Does this have the factory plug for plug in play with the factory harness. I like the mechanic advance up top.........my MSD for my 340 in the Valiant is like that. I wonder if the one I posted early has the advance set up like that. I'm trying to get Accel to send me some pictures of the inside of it.
Moparlee
Re: Mopar electronic ignition issues........troubleshoo [Re: Robbins] #458006
09/08/09 01:02 AM
09/08/09 01:02 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
It is aftermarket 3-wire hookup, one wire to keyed +12 volts, Negative side of coil, and ground. I think it does not use a ballast resistor, so you can bypass the ballast resistor. I just placed a jumper wire between the ballast resistor contacts, and plugged the connectors on to hold the wire, then just connected the distributor +12 to the positive side of the coil. I just grounded the ground wire to the coil bracket hold down bolt, and last wire just goes to the coil negative terminal. It is really simple to wire, and has worked great for me.
The newer version with the advance on top is nice if you change the advance curve often, but it is a more expensive dist. Otherwise it uses the same control module.
Re: Mopar electronic ignition issues........troubleshoo [Re: 451Mopar] #458007
09/08/09 04:09 PM
09/08/09 04:09 PM
Joplin, MO USA
Robbins Offline OP
Robbins  Offline OP
Joplin, MO USA
Ok.........I don't know.............if I'm going to go to the trouble of wiring something else up I might just MSD since I've got one in the 340 already.
Thanks again.
So nobody has a certain brand they think is good when it comes to factory style stuff as in Brain box, ballast heck even a stock dizzy?
Moparlee
Re: Mopar electronic ignition issues........troubleshoo [Re: 451Mopar] #458008
10/04/09 01:28 AM
10/04/09 01:28 AM
Joplin, MO USA
Robbins Offline OP
Robbins  Offline OP
Joplin, MO USA
Thanks for the help. I did find a bad ground which seem to be the issue. Knock on wood.
Moparlee
Re: Mopar electronic ignition issues........troubleshoo [Re: Robbins] #458009
10/04/09 07:17 AM
10/04/09 07:17 AM
Hamburg, Pa.
72 RR DUDE Offline
72 RR DUDE  Offline
Hamburg, Pa.
If it still does it after the ground problem here could be your problem. When I restored my 72 RR it did the same thing. It tried to start on the off position and not the start. Checked the wiring print in the book and I had the wires mixed on the ballast resistor. Put them on right and it fired right up. Hope that help's
Thanks Moparts
Re: Mopar electronic ignition issues........troubleshooting [Re: Robbins] #458010
10/04/09 09:25 AM
10/04/09 09:25 AM
The MP chrome box rather than the orange one
